You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
When the TeslaCam feature was release I figured it would be a good opportunity to play with and learn about the RPi Zero W's ability to emulate USB devices. I set out to build something that I didn't have to think about a solution that would automatically collect and archive the TeslaCam recordings.
Because the Tesla cuts power to the USB ports abruptly, I am using a PiJuice to keep the RPi online long enough to shut down cleanly -or- if WiFi is available rsync the recordings to server running in my home.
All of the code and documentation can be found on GitHub. (link below) I consider the code/implementation "good enough for me for now" I will make improvements as the need arises -or- if ya'll have feedback.
