You Can Summon Your Tesla Out of a Parking Spot
brucet999
2,671
1,482
Huntington Beach, CA
User's manual instructions for parking and unparking with summon state unequivocally that to unpark via "Summon", the car must have parked itself using "Summon".
Not true, I have discovered. I parked my car myself in perpendicular parking spaces, both front in and backed in, walked away until after the doors auto locked, and then returned and summoned it out of the space.
Could be very handy when some jerk has parked too close to your driver door for you to get in.
msnow
4,951
2,236
SoCal
This is right. I was able to initiate Summon via my iPhone sitting in my family room through two doors about 25-30 feet away. Key fob was in my pocket.
brucet999
2,671
1,482
As to the requirement for level ground, Max backed out of my garage, down a driveway that slopes 10" in 20 feet and stopped with rear wheels off the approach apron at the curb and onto the street gutter.
surfdoc
11
0
Del Mar, CA
Does anyone know the standard distance that it will travel after leaving the garage? I have noticed that sometimes it stops just outside my garage and other times it travelled almost out to the street.
Patrick W
1,476
882
SLC, UT
From what I've read, it's set to 39 feet. It would be nice if that distance could be set by the user.
When I've tried summoning from the garage, as someone else mentioned earlier, if I don't stop it manually the car backs out until the back is sticking out in the street.
- - - Updated - - -
I'm sitting here in a restaurant with the car way out of sight. After reading your post I opened the iPhone Tesla app and the Summon button is there. A little worrisome, actually. I hope that if I pushed it it would not work. But I'm not going to find out now. :)
brucet999
2,671
1,482
- - - Updated - - -
iPhone app "summon" button only works when the FOB is close enough for the car to sense it.
msnow
4,951
2,236
SoCal
i just updated my iPhone app and I don't see summons in the app
Just three conditions need to exist for it to work.
1. 7.1 installed and Summon enabled
2. Phone and fob need to be close together
3. You need to be 10' from your car
This last point still needs to be tested if you can be farther.
msnow
4,951
2,236
SoCal
- - - Updated - - -
Did it work?
Rockster
3,007
4,611
McKinney, TX
I discovered today that you can even "summon" the car while sitting in the driver's seat. Strange, yes, but it works. We found an empty parking lot and moved the car forward and backward using only the key fob, all while seated in the car.
