dareed1
We have a 2100 sq ft house built in 1968. Since then we have added R-38 in the ceiling, double pane windows, and perhaps 1/2 of the walls are now insulated due to various remodeling. We installed a 2.5 ton Mitsubishi heat pump. I had to insist on such a small system (contractor recommended 3.5 or larger), and I did my own Manual J calculation using CoolCalc. It is free, but I paid $10 to allow me to output the calculations to a PDF file. Gathering the data for a Manual J calculation involves finding out the thermal properties and size of windows and the dimensions of the house. It took me a couple of hours to get through everything. The reason I wanted a small capacity heat pump is that smaller ones tend to be more efficient, and I want the PWs to last for a while during a power outage. I did the calculation myself to give me confidence that the numbers were reasonably correct.
I installed solar panels plus PWs first, while we still had a gas-fired furnace. Historical usage was about 12-14kWh per day, and Tesla recommended a 4kW solar system. I told Tesla that we planned to switch from a gas furnace to the heat pump, so they were willing to spec a 8kW system. I told the Tesla installers that I would need space in the electrical panel for a 20A breaker (240V) for the heat pump. They left the space, but still put the Add No Loads sticker on the panel. Later the HVAC contractor had no concerns installing an additional 20A breaker to power the heat pump in spite of the stickers.
That is a feature of inverter based compressors--low starting current. Mitsubishi doesn't even provide a LRA spec, but they do spec the recommended breaker size.
