Zuma Satellite Reportedly Destroyed Following 1/8/18 Launch By SpaceX
Discussion in 'SpaceX' started by TMC Staff, Jan 9, 2018.
Tags:
  1. SMAlset
    SMAlset Well-Known Member
    SF Bay Area
  2. Grendal
    Grendal SpaceX Moderator
    Santa Fe, New Mexico
    #182 Grendal, Apr 9, 2018
    This article doesn't seem to be behind a paywall:
    Zuma satellite plunged after SpaceX launch because of Northrop Grumman errors, report says
    The implication from the article is what was reported early on: that the payload adapter failed and the satellite did not separate from the second stage. The only thing that surprises me about this is that I don't understand why they wouldn't have left the second stage in orbit to try and correct the issue. I'd love to hear the details but the classified nature of the launch will probably prevent that from happening.
    The Verge's article by Loren Grush (who is a big SpaceX fan) gives a smackdown on Northrup Grumman for the failure and brings up the delays with the James Webb Space Telescope.
    SpaceX isn’t responsible for loss of Zuma spy satellite, WSJ report confirms
  3. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    #183 ecarfan, Apr 9, 2018
    Quote From this article Northrop Grumman, not SpaceX, reported to be at fault for loss of top-secret Zuma satellite
    “The investigations tentatively concluded that onboard sensors did not immediately communicate to ground systems that the satellite did not separate from the rocket, according to the Journal. Unbeknownst to officials at the time, the planned return of the rocket's upper stage — a method of disposal to avoid adding space debris around the Earth — brought the satellite back down with it. By the time the satellite separated from the rocket it was too late, putting Zuma too low in orbit to save, according to the report.”
    So maybe the sensors falsely indicated that separation had occurred? Because otherwise the de-orbit would not have been initiated. It’s not entirely clear to me. If the sensors did not indicate to that separation had occurred, what did they indicate?
    • Informative x 2
  4. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    That explains all the finger pointing that was going on.
  5. ccutrer
    ccutrer Active Member
    Eagle Mountain, UT
    If only SpaceX could have shown the camera view of the satellite separation during the livestream, this all would have been obvious</troll>
    No, but really. Did they not have a camera on the satellite from the second stage, watching it separate?
  6. mongo
    mongo Well-Known Member
    Michigan
    Possibly not, due to the security aspect. However, it does seem the amount of thruster usage/ time to rotate needed for the de-orbit maneuver could have indicated the mass of the second stage was not as expected. Unless it was some weird situation where they were physically separated, but linked by an umbilical. Or, more likely, parameters like that are not closely monitored after (expected) payload separation.
  7. Pricee2
    Pricee2 Member
    Snohomish WA USA
    Did they find Zuma yet?
  8. Grendal
    No. It's classified. The belief is that the satellite did not disconnect from stage two due to a fault with the connector. The connector was controlled by NG and SpaceX was excluded from touching it.
  9. Piney999
    Piney999 Member
    East of Pikes Peak, Earth
    The "Belief is" ;)
  10. SO16
    SO16 Active Member
    MI
    Directly over your house!
  11. Pricee2
    Pricee2 Member
    Snohomish WA USA
    My belief is that SO_S90D is most likely to have the answer that is closest to the truth..
  12. Grendal
    No news at all about this suggests, to me, that Zuma was destroyed as most have reported. Anything else borders on a conspiracy theory.
  13. Graffi
    Graffi Member
    San Diego, CA
    Just because you call it a "Conspiracy Theory" does not mean the Government is not watching you. JMHO
    • Funny x 2
