Just started to use home assistant to automate many parts of the house, would now like to connect it to the Tesla.
Ideally I'd like to view:
This additional integration is available through the HACS extension:
Can anyone help with recommendations as to which integration you find works best, either from the above links or from other repos? I'd prefer the car not to be kept awake 24/7.
Would also be great to see how you've configured it, and how the car data appears on your home assistant dashboard, if you'd be so kind as to share screenshots.
Thanks!
- Current charge level
- Plugged in/unplugged status
- Internal cabin temperature
- Charging status
- Locks
- Defrost/climate
HomeAssistant Integration | TeslaMate
Whilst HomeAssistant provides an official component for Tesla vehicles, the component has not been updated recently, and does not have the sophistication of TeslaMate's polling mechanism, resulting in the component's default values keeping the vehicle awake and draining the battery.
docs.teslamate.org
GitHub - alandtse/tesla: Tesla custom integration for Home Assistant. This requires a refresh token be generated by third-party apps to login.
Tesla custom integration for Home Assistant. This requires a refresh token be generated by third-party apps to login. - GitHub - alandtse/tesla: Tesla custom integration for Home Assistant. This re...
github.com
Thanks!
