To arrive at a range distance calculation, the EPA subtracts a set percentage of the tested distance for heating and cooling. Because the Model Y’s heat pump is so much more efficient with power than resistance heating, real range is likely to be better than the EPA would estimate. What is your range and under what conditions - weather, road surface, general wind direction and strength- did you experience that range?
