SF Bay HPWC
Greetings, I am inquiring whether anyone in the SF Bay area has an original Tesla HPWC that I can charge my 2010 Roadster Sport on as a test. I have an evolving problem charging my car that has been difficult to understand. Charging just stops at approx 55% of battery capacity. The local Tesla Service center has done diagnostics and an annual service and says that my car is fine and there must be a problem with my home circuits or my charger. They recommend that I try charging the car on someone elses equipment. I find this hard to understand since I have the same problem at 3 different homes on their 115 V outlets with the original yellow cord, at 2 different homes with 2018 and 2020 S/X/3 240 V wall chargers and my Sharp CAN Sr, and at a home with the 240 V Mobile connector 14-50 Adapter and my CAN Sr. Still, I want to comply with the service center’s suggestion and eliminate the CAN Sr as the cause. Thanks, W
Unusual to have your charging circuit affect the SOC. If your SOC is maxed at 55%, it may be an issue with a resistive cell(s) in the brick(s).
The max SOC is determined by the weakest brick. Get into the diagnostic screens (tab empty area on vms, 1050 enter, Ess -> SOC screen) and see the delta for SOC min and max. It should be 2-4% delta.
Thanks for your input. I am attaching a photo of the screen you requested but I have no idea what it means. The service center said that charging was completely normal.
Ugh! It looks like your pack is starting to fail. There’s a huge difference between min SOC @48% and max SOC @91%. As @ML Auto pointed out, post the pics of your other ESS screens. The Vmin will show the brick in trouble.
Connect the charger for 1 to 2 months in Standard mode, allowing time to balance. The delta should come down with some 1% to 2% per day. Had the same issue here.
Even if the pack is healthy, I don’t think the pack can self rebalance with a delta of over 40. That would require a manual balance of the individual sheets.
At this point, I would pull a log set and get that info to a roadster guru. I believe you’re near Jamison’s (first tesla master tech) ev shop.
Good luck and keep us posted of the fix.🤞
Reactions: MCroadster
