father_of_6
Membler
Did you check with the service center if they warrantied the repair?
Good idea. I'll do that. Thanks.
This is not a Meyle control arm if you compare the picture from the link you posted. 2024 Model Ys must be using a new Tesla aluminum arm, but it isn't made by Meyle.Meyle sells an upgraded part that is showing up on the new 2024 Model Y's. (Meyle Control Arm Set for Tesla Model 3 2018+ and Model Y 2019+).
It seems like you will be bracing it almost every 2-3 years after the first replacement.Well this sucks. My 2021 has around 56k miles now. I guess I should be bracing for this.![]()
Did they do an alignment afterwards?Out of warranty, had them replaced for 200 for both upper control arms yesterday. No laborCreak is gone....now if only the AP computer would get recalled/fixed
Alignment is not changed during an upper control arm replacement. The upper control arm mounts do not get moved, which is where your adjustment comes from. Tesla's service manual states no alignment required for just the control arms. Good chance none was performed.Did they do an alignment afterwards?
Cool. I know on some past ICE cars I had, depending on badly the part was worn, alignment check was recommended so just thought I'd ask.Alignment is not changed during an upper control arm replacement. The upper control arm mounts do not get moved, which is where your adjustment comes from. Tesla's service manual states no alignment required for just the control arms. Good chance none was performed.
Someone in another thread just confirmed that the 2024 Ys are using a new aluminum upper control arm, hopefully these start to get used as warranty replacements, assuming the ball joint is improved finally.
While on this topic, I work in a high rise with corkscrew ramps leading to the upper parking decks. When going down or up, I sometimes hear what I thought were suspension clunk noises as I exit the corkscrew. I'm not not 100% certain however, as it could be the washer fluid pent up from the g-forces sloshing back and slapping the tank. The only reason I haven't taken it for Tesla to check is that I don't seem to hear the noise anywhere else, which leads me to think it's indeed, the washer fluid. It is a very prominent sound in the front end and sometimes I can hear a liquid slapping but sometimes it sounds like a mechanical hard part issue. Just a strange phenomenon that I noticed with this car. I plan to let the washer fluid completely run out before the next refill, so I can test the theory.
We see Meyle all the time on the BMW side, it's OEM equivalent - nothing more, nothing less. Powerflex now offers replacement control arms with polyurethane bushings already pressed in:Meyle "HD" parts are junk in the European car world. They are not HD, it's just marketing. OEM BMW/Volvo/MB/etc. (Lemforder usually) are always better quality. I'm not sure how Tesla OEM control arms stack up, but time will tell if the Meyles last more than 30K.
They won't, though you can ask them to "check" the passenger side because you're "not sure."I'm taking my car in for this issue next week. It seems to be only on the driver's side. Will they replace both? I'm at 47k, so warranty repair but would rather have both done....
I agree, if they were replaced once they should still have warranty. My SC is very reasonable, I was able to reason with them and they helped me out.Dang man. Why do Tesla parts keep breaking!? I just don't get it.
I'm like, you. I think there should be insurance for suspension issues. Did you check with the service center if they warrantied the repair? They might be able to replace it free of charge.
Inject more. Sometimes it can take 100 miles of driving for the grease to work its way into the joint and stop the squeak.I did this recently (syringe, grease, boot) but the creaking came back the next day. Feeling defeated. I'm at 53k miles and had both FUCAs replaced under warranty less than a year ago.
Funny thing, I took my my Tesla shop for alignment yesterday(got new tires a week ago too), Tesla didnt tighten lugnets on right side and was missing 1 lugnet. Also one of the Bolts was installed opposite direction....back to TeslaDid they do an alignment afterwards?
