EDITOR’S NOTE: This is a sponsored post from Jedlix. A Dutch version of this article is below the English version.
In a few years, the rest of the world will follow the standard set by Tesla drivers: they will make the switch to an electric vehicle. No more emissions, everyone will simply charge their vehicle when they come home at night, or during the day while they are working. There is just one problem: if everyone starts charging at the same time, the grid will not be able to comply with this peak in demand. Jedlix found the solution, it’s called Smart Charging – an ‘over-the-air’ charging solution that ensures your Tesla gets charged on moments when there is enough renewable energy available on the grid for the lowest price. The best part: you receive a financial reward for each Smart Charging session.
In 2016, Tesla became partner of Jedlix. Through this partnership, Tesla drivers are able to smart charge their Tesla via the Jedlix app.
An example, when you come home at night and decide to charge your Tesla, you might not need it again until the next morning. All you have to do is set your departure time and the app takes care of everything else. Via connected-car technology, Jedlix is able to communicate with your Tesla. Based on your departure time, battery status and the availability of renewable energy, the app creates a unique algorithm that calculates the optimal charging moments and ensures your Tesla is fully charged when you need it.
Smart Charging is easy
To start Smart Charging, you need to create a Jedlix account. You fill in your name, address and type of Tesla. Once these steps are done, we ask you for your Tesla credentials. Because of the close partnership Jedlix has with Tesla, Jedlix is able to make direct contact with a Tesla, but only with the permission from the owner. When a user logs in with their Tesla credentials, Jedlix receives a token from the Tesla API. Jedlix encrypts this token and saves it. This token acts as a key that Jedlix uses to connect with your Tesla. You do not need to worry about security, as we only save the token, not the credentials. Once your Jedlix account is set up, you fill in your energy contract and your preferred departure time and you are ready for your first Smart Charging session with Jedlix! Just make sure to check the app once in a while to redeem your savings. Savings can be redeemed from EUR 5.
“Jedlix charges my Tesla when green energy is generated, in this case I contribute to the most effective use of green power. The financial reward is a nice extra.”
– Wout van der Heijden, Tesla Model S owner
For more information about our service, please watch our explanation video.
To start Smart Charging, download our free app for iOS or Android.
(Dutch below)
Binnen een paar jaar zal de rest van de wereld het voorbeeld van Tesla-rijders volgen: iedereen zal switchen naar een volledig elektrisch voertuig. Weg met emissies! Heel Nederland zal dan ’s nachts de auto thuis opladen, of overdag op het werk. Toch blijft er één hardnekkig probleem: als iedereen op hetzelfde moment begint met laden, piekt de vraag naar (groene) stroom. Het energienetwerk kan dat niet zomaar opvangen. Gelukkig heeft Jedlix heeft de oplossing: Slim laden, een ‘over-the-air’ laadoplossing die ervoor zorgt dat jouw Tesla wordt opgeladen op groene en goedkope momenten.
Sinds 2016 heeft Jedlix een partnerschap met Tesla. Dankzij deze samenwerking kun jij je Tesla slim opladen met de Jedlix-app. Slim laden zorgt dat je Tesla alleen wordt opgeladen op momenten dat er genoeg (groene) stroom aanwezig is op het energienet. Die optimalisatie zorgt voor lagere energieprijzen. En het grootste voordeel: omdat je helpt het energienet te balanceren, ontvang je een financiële bonus voor iedere slimme laadsessie.
Hoe Slim laden precies werkt? Stel, je komt ’s avonds thuis en je hangt je Tesla aan de stroom. Het enige wat je dan nog hoeft te doen is je vertrektijd instellen in de Jedlix-app. De rest gaat vanzelf. Via connected car-technologie communiceert Jedlix met jouw Tesla. Het unieke algoritme berekent de optimale laadmomenten op basis van je ingestelde vertrektijd, de status van je batterij, en de beschikbaarheid van duurzame energie. Zodra jij weer op weg moet, is je Tesla volledig opgeladen met duurzame en voordelige energie.
Beginnen met Slim laden is simpel
Om te beginnen met Slim laden heb je een Jedlix-account nodig die je eenvoudig aanmaakt in de app. Vul daarvoor je naam, adres, en het type van je Tesla in. Daarna wordt er gevraagd om in te loggen met je Tesla-credentials. Dankzij de nauwe samenwerking met Tesla kan Jedlix direct contact maken met je voertuig, maar uiteraard alleen met jouw toestemming.
Zodra je inlogt met je Tesla-gegevens, ontvangt Jedlix een token van de Tesla API. Die token versleutelen en wordt bewaard om verbinding te kunnen maken met je voertuig. Je logingegevens worden niet opgeslagen, dus over de veiligheid hoef je je geen zorgen te maken.
Voeg tot slot de details van je energiecontract toe en stel je vertrektijd in, dan kan je eerste slimme laadsessie met Jedlix beginnen! Check daarna af en toe de app om je bonus te claimen. Dat kan al zodra je 5 euro hebt opgespaard.
“Jedlix laadt mijn Tesla op wanneer er duurzame energie wordt opgewekt. Zo draag ik bij aan het meest effectieve gebruik van groene stroom. De financiële bonus is een fijn extraatje.”
– Wout van der Heijden, eigenaar van een Tesla Model S
Meer weten over onze service? Bekijk onze uitlegvideo over Jedlix.
Klaar om te beginnen met Slim laden? Download dan onze gratis app voor iOS of Android.
