Wow, that did work just now. Thanks! I'll try some more but like I said, working once is likely always working. That saved so much trouble. Only issue was that the first couple times I tried to turn on voice command (the right button on steering wheel), it failed with displayed message "connection error". Not sure what it needs to connect for voice command. Still, this is way way better than having to manually pick the song again, which caused me to usually listen to the same songs again and again.To save even more time simply say “USB”
