That one probably is.. I see its getting twice the expected power out of a 235V by 16 amp line.Good guess. Its charging on a 7KW supply from a public charging station. Are they usually a 3-phase
I saw you are from Leeds, and that's what drove me to think 3-phase.Sorry, I didn't mention that I am from the UK. In the US it could be the case as I think its the 110V there so a 3phase might be required to get 7KW charging
it's 3 phase. I have it at home as well (wall connector from Tesla) and as mentioned in earlier comments, the power (kW) indeed suggests 3 phase; if it would be single phase you can't get 7KW from 16A and 235V; you would have more or less halve of the 7KW. With 3 phase though, I think the formula sounds 16A * 235 V * sqrt(3) = 6.7KW -> rounded 7KW.
In england(and probably europe), the standard Tesla connector has what appears to be four power leads(five if you count the ground). They are probably feeding the three phases in on three of those power leads, and the innards of the PCS either deal with each lead to ground separately or they do some internal magic to combine them. At least in the US, the PCS has three modules, each capable of dealing with 16A/240v (actually more, 16A/290V or so) which is still MUCH less than an EU tesla can deal with on AC.The Tesla connector only had two power conductors that AC power goes over. It sends that to the cars inverter to switch to DC. I thought with 3 phase it just uses two of those thus many public level 2 chargers are 208 volts.
Yes, you are thinking that the North American version of the wall connector you are familiar with is the same used all over the world, but it isn't. They have a different version of the wall connector sold and used in Europe that doesn't just have two conductors for the voltage. It is made to be able to use 3 phase with all three hot conductors and pass them all through (using a different kind of plug) to the cars, which have the Type2 port, which is made to use 3 phase electricity natively.Conceptionally I don't understand how the Tesla can utilize the power of all 3 phases? I'm in the US.
I must be misunderstanding something.
