Same for me, received the update yesterday and really like the UWB and the auto trunk updates. What exactly is the improved auto shift going to do differently? Really like auto shift right now and excited for any updates on that.So I finally got 2024.14.9 last evening. Must say the UWB for detection is far superior than bluetooth. No need to sometimes pull the phone out of my back pocket any more. The auto trunk works really well also. Just a little disappointed I did not get the improved auto shift just yet but must assume it is not far off. I have an early build Dec 21, 2022 MS. There was talk about UWB not being available in the earlier MS builds but can confirm mine does have it.
Are you sure you don’t have it? They moved the location of where it was from the original. I have 2024.14.9 and I have it I’ll check in a few for the updateSo I finally got 2024.14.9 last evening. Must say the UWB for detection is far superior than bluetooth. No need to sometimes pull the phone out of my back pocket any more. The auto trunk works really well also. Just a little disappointed I did not get the improved auto shift just yet but must assume it is not far off. I have an early build Dec 21, 2022 MS. There was talk about UWB not being available in the earlier MS builds but can confirm mine does have it.
I may however I have backed out of a few places and turned the yoke however it has not shifted into forward like it should according to what I have read. I do have Auto Shift (beta) switched on. It is in its infancy so maybe not very reliable yet?Are you sure you don’t have it? They moved the location of where it was from the original. I have 2024.14.9 and I have it I’ll check in a few for the update
It's a little unintuitive because you have to turn the wheel and hit the brakes for the direction to change. The screen should show the promptI may however I have backed out of a few places and turned the yoke however it has not shifted into forward like it should according to what I have read. I do have Auto Shift (beta) switched on. It is in its infancy so maybe not very reliable yet?
Never use the brakes so maybe thats why. Will try later on today and get back on the results.It's a little unintuitive because you have to turn the wheel and hit the brakes for the direction to change. The screen should show the prompt
To be clear, you just need a quick tap on the brake pedal and then turn the wheel after that, you don't have to hold the brake or brake while turning the wheel. Wait for the chime before pressing the accelerator again. If you hit the accelerator before the chime, it will cancel the change.Never use the brakes so maybe thats why. Will try later on today and get back on the results.
Interesting. I also received the update but I got both the UWB and new auto shift. I have an MS with a September 2022 build.So I finally got 2024.14.9 last evening. Must say the UWB for detection is far superior than bluetooth. No need to sometimes pull the phone out of my back pocket any more. The auto trunk works really well also. Just a little disappointed I did not get the improved auto shift just yet but must assume it is not far off. I have an early build Dec 21, 2022 MS. There was talk about UWB not being available in the earlier MS builds but can confirm mine does have it.
If you back out of a parking space it is supposed to shift into forward as opposed to you doing so on the screen. As with anything new, it will only get better with time.Same for me, received the update yesterday and really like the UWB and the auto trunk updates. What exactly is the improved auto shift going to do differently? Really like auto shift right now and excited for any updates on that.
Because the entire UI on the S/X is an afterthought and Tesla didn't bother making a variant of that UI that makes sense with having the driver display.Why on 2022 model s we do not have on v12 the car that can be turned around for features like open trunk frunk and so on?
