Clarity around CAC imbalances, voltage imbalances, bad bricks, and battery warranty - 2015 90D
Here are the non driving numbers.
Tesla says it's only 16% degraded
Hmm.. ur full rated on the other post shows 207mi
Depending on what rating u use, i get either 23% or 18% degradation (270mi or 253..)
Check out this thread:
8mV imbalance is really good.
This mornings 80% charge numbers.
So my 80% charge for the last 5 years (depending on the time of year and temp) 199-205, starting about actually dealing with this for about a year now. My 80% charge numbers range from 156-161. Plus when I bought the car it was already 1.5 year old, so I figured the normal degradation had already happen. So just take those numbers into play, its around 78% not taking into factor the first owners normal first year degradation.
I'd just like to know the nominal rating of the battery new so I can show them what it is now?
Are there any test/reading that I need to do? Full charge reading?
Also how do you all get the graphs that are attached to your other pictures to show historical data?
I think I signed up for teslafi years ago @hybridbear let me look.
62.6 kWh Nominal full pack is REALLY bad and probably going to fail soon. I would suggest "helping it" if you are still under warranty. For reference my 90 pack is 76.9 kWh with 83k miles.
@seenhear @hybridbear You need to go into the Google store settings and sign up for the "Join Beta" for this app to get the new visuals and CAC values.
Here is a Android screenshot of the beta version on my 3/2016 MS 90D.
@ajadan Let us know the specs of the new pack once you get it replaced under warranty 😁
How do you "help it" along to failure?
The SMT Beta has lots of issues. I had tried it before. Is it still unable to customize tabs like in the normal version? Until the customizing is there I won't change over. I only really use my customized tab with the values I want to see.
Also, I don't see CAC in your screenshot...
Reactions: seenhear
See post #4 and #12. Stress and heat, pretty much doing the opposite of what's good for a battery. 😇
It was in the app but cutoff on that screenshot. I tried to get it again just now but that field wouldn't populate. Like you said the beta app is a little buggy 😂
Reactions: cleverscreenam
Same experience here.
Yes, a drive plus leaving Phone connected for 20 minutes in car revealed a +/- 0,8% CAC imbalance on Model S 70D October [email protected]:
And total capacity of approx 221Ah * 3,6V * 6 Bricks * 14 Modules = 66,83kWh total to compare with 71,2kWh new
My usage pattern is charge as little and often as convenient and center around 40% SoC and all long resting should be < 55% SoC.(55% when NCA, 60% when NMC) .
As stated elsewhere the SMT BrickId is partly an integer and partly a Float and often way out of Range, say 111 on my 84 Brick battery :) I will report to SMT Beta.
I opened another ticket with Tesla 2 weeks ago, this time the said it was due to the CAC imbalance, my Android version still won't ever give me the CAC numbers so I borrowed an old iPhone from work and got the following numbers. Tesla remote tech suggested charging to 90 for a few charge cycles and to 100% a few cycles while allowing it to discharge to 60% or less each time. Then closed the ticket a week later before giving me what he thought the results were after those test.
20.4AH of lost is only about 10% loss, and my Nomial full pack has also last another 1kWh since my July post above.
At 20Ah CAC imbalance your pack is hanging by a thread
@Zelectric if still under warranty, my understanding is that a CAC inbalance of >20% is grounds for in warranty pack replacement. Looks like you're halfway at 10%
That said, there is some indication that ScanMyTesla does not provide an accurate reading of CAC imbalance. This discussion over on Facebook will help.
From the link "one note on SMT. it does display min/max CAC in the latest version and is great improvement. however, we’ve seen some variability in the numbers it reports - in fact, we saw a 4 Ah discrepancy just this morning. and the brick IDs are all over the place for some reason. sadly totally unreliable currently
we’d suggest getting CAC from second source before running for the hills. we always use raw CAN data directly from the BMS to avoid any issues"
