Constant VCFRONT_a59 error
I just recently got a used 2022 used model 3 long range edition and was checking it over in the service menu to see if there was anything triggering that I might need to get it looked at.
I've noticed for as far back as the service alerts go there is a VCFRONT_a059_inputresistancehigh alert triggered and cleared almost every 2 minutes the log goes back at least 3 days and this is triggered almost every 2 minutes and in today's log and only today's log I also saw one instance of a DIF_a018_hwLVSupplyUV that was triggered then cleared almost an hour and 20 minutes later which seems to indicate the low voltage battery was possibly a little low but I don't see that triggered on any other day.
Is there something I should worry about and get service scheduled could this possibly be a bad low voltage battery?
I get the same 2 faults since I had the car. Looked around in forums and saw others with same faults and service center claim no issue with this nuisance fault since its only in service mode not customer facing. Have left it alone. Numerous road trips, and no issue.
