Curb Mass | Payload | GVWR table w/diff AS-vs-AT & Tri-vs-Dual
scottf200
6,224
7,474
Chicagoland
Usage:
a) analyze AS vs AT weights and distributions (orange header) ie. curb, GVWR, payload
b) analyze Tri vs Dual weights and distributions (purple header) ie. motors, e-lock, etc
I spent some cycles converting that screen capture of CT weights to a Gsheet so I could do some simple math to show the differences of
- tires: AS (all seasons) vs AT (all terrain)
- powertrains: Tri vs Dual
[Note: I did use an OCR tool but then had to do a fair number of cleanup edits. I double checked the numbers but let me know if something is amiss]
lb
kg
Reactions: evo9rs
I think the below highlights indicate that the Tri-beast extra motor+gearbox is ~180.5 lbs [AVG(K4,L4)] ...
but why would the front axle be ~48.5 lbs [AVG(K3,L3)] heavier (see cells right above the purple rectangles)?
Reactions: evo9rs
