DC v AC EV system ?
Cobos
Model S owner since 2013
1,575
3,060
Oslo, Norway
I feel a bit stupid asking this, but could someone please explain to me what the rationale for a DC or a AC system is ? It seems all personal EV conversions use a DC system while Tesla and I believe Think both uses AC.
Am I correct when I assume AC is more expensive, but why then doesn't every EV use DC ?
Cobos
I could be wrong about this. . . But I don't think you can do regen with DC? Also many DC motors have brushes or permanent magnets, or both, so there would be more maintenance issues in the long run.
Somebody who knows more about motors will probably give a better answer.
Brushed DC motors can do regen with the right controller, but it takes a more sophisticated, (expensive) controller and it can often be hard on the brushes, so it's not really practical.
Brushed DC is used for most conversions because it's the cheapest way to get the most performance for your dollar.
I agree with JRP3, DC is easier to do.
AC induction is more complicated technically, but in terms of parts, I think it may actually be cheaper (no need for permanent magnets). I think AC also gives a smoother experience at very low speeds--the magnets in a DC motor cause a noticeable lurch as they turn over.
-Ryan
-Ryan
From what I see it seems AC conversion kits cost a little more than DC conversion kits by a couple thousand dollars. AC motors also seem to cost a little bit more than DC ones for one of around the same weight/power/efficiency. Probably has to do with avaliability of AC motors, as DC motors seem more widely avaliable for the EV conversion market. Though I suppose complication probably has the most to do with it.
-Ryan
Yes, that is my understanding as well.
I have also heard that you can have more control of an AC (induction) motor.
With DC (permanent magnet) you just put current and voltage into it and it basically spins as fast as it wants. With AC you are controlling the magnetic fields directly. It is ***much*** more work for the controller but then you have much more control over the RPMs of the eMotor. To try something ambitious like clutchless computer controlled shifting (with exact rev matching) might be more possible with an AC motor (although it sounds like Tesla didn't pull off that magic trick just yet).
There are also differences in the way the torque and efficiency curves map out over an RPM range so there are different trade-offs between the two technologies.
