Do you still have the related faults in Service mode?my flap has probably repaired itself. Also opens again at the Supercharger
I had a frozen evap plug……I have no error codes /messages. I think it’s just strange….They sent a repair estimate without seeing the car and all the louvers work properly. I’m pretty sure I’m just gonna cancel my appointment and have a tech add some refrigerant.
I think there's no such possibility. But apart from the standard calibration procedure there's also another one called "Angle fix". That one might be helpful for you.I noticed today that my ventilation flap on the right side no longer works. I then put my hand in and pushed the ventilation flap a little into the closed position, during which it closed and the feedback error disappeared immediately and both flaps opened again on the supercharger. Is there any function in the Tesla Toolbox to change the opening angle of the ventilation flaps? It seems to me as if the right flap opens and closes too far.
The positioning doesn’t matter - all actuators turn every time you open the charge port or start the car to redetermine their ‘limits’. You can prove this by disconnecting then reconnecting - it will always move in the same directionI might think if this issue that OP is describing will return then there might be possibility that the fins rotating axle have shifted one tooth on the actuator, hence the temporary manual assisting resolving the errors. Photo attached.
But do we know this for a fact or just a generalized assumption because we physically see the shutters/louvers move? There does appear to be a feedback signal that reports errors to the alert screen in Service Mode. Is there a separate sensor that determines this feedback or is it integrated in the actuators?The positioning doesn’t matter - all actuators turn every time you open the charge port or start the car to redetermine their ‘limits’. You can prove this by disconnecting then reconnecting - it will always move in the same direction
It’s fact insofar that it’s the behaviour I have seen on all four actuators with my own eyes. There would almost certainly be an index spline if the position was criticalBut do we know this for a fact or just a generalized assumption because we physically see the shutters/louvers move? There does appear to be a feedback signal that reports errors to the alert screen in Service Mode. Is there a separate sensor that determines this feedback or is it integrated in the actuators?
It sure would be nice if Tesla or someone extremely knowledgable with Teslas would confirm how this system works. My service alerts have included:
THC_w0134_radRightShutrNoFeedbk
THC_d0018_activeAero
I can confirm that the shutters on the left and right side of our 11/13 built S85 do in fact open and close when starting the car, connecting to the car, and open while Supercharging. Using a FLIR One thermal imaging camera indicates a temperature range of 104-116F on the radiators behind the shutters.
Ever since the mid-2019 software updates, our Supercharging curve has been less ideal. Charging from 20-90% SOC takes twice as long as before and so I've switched to Supercharging between 10%-70% to save time. Over the last 3.5 years, the SOC + kW sum has been around 80-138. A curious thing happened while I was on a solo trip from Napa to Orange County, Ca. I stopped at an empty V2 Supercharger with 8% and the maximum charge rate was 74kW at Kettleman City (probably equipment issue). But my following stop in Tejon Ranch with 10% at an empty V2 hit a maximum charge of 134kW which I've never seen before. The SOC + kW sum was around 110-144. I was on my way in half the time I had expected. Unfortunately, it appears that was a one-off. I got to an empty V3 site with 11% and the max rate was 98kW and quickly dropped into the 70s. I ended up charging in Tustin for 1h50min. Not sure why Supercharging was so much faster at Tejon and I'm curious to know if the radiator alerts are related. I might have to have the Service Center take a look before my next roadtrip because that could be a gamechanger if 134kW can be my new normal. I was so thrilled that I took a picture in disbelief.
Not quite right, see this post…I believe I am the first person to have successfully repaired an external Louver.
This surely would be the reason for the ‘calibrate’ procedure in Toolbox?Sorry, I had to translate it using Google Translate. My Louver has now been replaced 6 times by Tesla because the error THC_w0126 always reappeared after about a month. The Louver moves to the end position every time the vehicle is restarted; it does not need to be trained, which is defined by this pin. The pin is already sitting far too loosely in this passage. This causes the pin to twist in its opening. This means that the engine can drive the Louver much further than the old Louver used to do. I have now pushed a cable strap through the opening so that the cable strap eliminates the play in the opening and at the same time functions as an intermediate piece for the end stop. I once tried to make a video with a louver that was already broken, but I only had two hands. I think the error message THC_w0126 doesn't mean "no fedback" it means more "more motor movement as defined in the software" because the motor definitely moves too far in the "up position"
This repair is the consequences of the feedback error. Each time the flaps open so far that the blades hit the bottom of the bumper, the pin on the blade then breaks off.Not quite right, see this post…
