I noticed my HPWC has recently started behaving differently. Usually when connected to the car which is charging, pressing the button on the handle stopped the charging, the ring on the charge port turns from flashing green to white, the charge port unlocked, and I can remove the handle from the car.
Rencwntly I have noticed when I press the button on the handle that the charging stops momentarily then starts back up charging again (charge port goes from flashing green to white then back to flashing green). Sometimes when if I’m not fast enough to remove the handle while, the HPWC indicator turns red and I have to turn the breaker off and back on to reset it.
I’ve noticed it on both my Model X and Model S. So I don’t think it’s car dependent. Also, if I stop charging on the car center screen, the charging stops and the charge port ring color remains white and there is no problem removing the cable.
Anyone else experience this or know what may be happening?
