HTTPS?
bmah
Moderator, Supercharger Hunter
Global Moderator
Mar 17, 2015
5,989
13,757
Lafayette, CA, USA
I wasn't able to find any query like this in the forums so far so...
Any chance of getting the forum to work over HTTPS instead of (or in addition to) plain HTTP? It sort of halfway works for the first page load, depending on browser settings, but then any click seems to go back to using HTTP.
One reason to do this is the when users login, at least some part of their credentials get passed in the clear over the network.
Thanks!
I hear ya. I'd like us to switch to https exclusively, but vBulletin, our current forum software, does not make it easy. The problem is there are a lot of non SSL elements, e.g. externally hosted embedded images, etc. Most modern browsers will basically block the entire page when that happens.
We're looking to migrate platforms, which will get more attention after TMC Connect. Note that the event website does have SSL.
In a way it's comforting to know I'm not the only person who's thought about this.
Cool, thanks!
Bruce.
Have you considered an SSL front end/load balancer that would do the SSL on the client side but leave the backend non-SSL? Not ideal if done incorrectly, but could be done with one of many services, like an AWS Elastic Load Balancer I believe. Can also get IPv6 support this way.
Isn't TMC on AWS now? Should be relatively straightforward to put the site behind an ELB and enable SSL on the client side of things. Would only be non-SSL internally at that point. I've done this previously, and it works reasonably well.
(I had this discussion recently and.... I can't remember if it was here or not....)
^ I still think this is probably the best bet for pretty much immediate IPv6 and SSL support for TMC. :-D
The issue isn't the cert. It's the mixed elements on the forum. Of course we use SSL on the TMC Connect registration site which is the same domain. Well be full SSL when we change platforms, which will be soon. Perhaps by next week if I can cross all the Ts.
