AFAIK there is no one that had been able to revive a Tesla 16V battery externally after it goes fully dead (as in contacts disconnected by BMS) other than cutting the top off and charging cells directly by bypassing the BMS. The only working way to possible revive one is on a working Tesla, which the OP doesn't have and the SCs are refusing to help.
Unless you have personal experience with that 16V battery charger working, I would not go around suggesting that as if it works.
None of that applies to a dead Tesla 16V battery through the BMS. You have experience working with bare cells or at least a connection to bare cells, but a dead 16V Tesla pack cuts off the connection so unless you can "wake" the BMS (which the car can) there is no way to charge the cells back up.
I have a double major and degree in EE also and I have experience with battery BMSs. In fact I am working on reviving a dead laptop battery pack right now. If you pop open the pack, it's easy to charge the individual parallel cell groups with a standard 18650 charger (just take some leads to connect them to the tabs) or even charge them with a 3S charger by connecting to the bare connection to the 3S negative and positive. However, there is no way to do that externally if the BMS has a permanent flag (for example mine has a under voltage flag from sitting too long discharged much like the OP's 16V battery), which permanently turns off the power FETs and essentially disconnects all external power (in or out). Even if you swap in new cells or recharge the existing cells to full, no power is allowed in or out. The one I'm working on is specifically a TI BMS which requires a manufacturer password to "unseal" the BMS before that flag can be cleared. These types of BMSs have been in use on laptops for literally decades.
I imagine Tesla has a similar BMS on theirs. My laptop's battery uses SMBus data communication. Tesla's uses LIN data communication for theirs. In contrast there is no data communication between the 12V lead acid and the car, it's just a dumb battery.
Just released is a detailed, but not overly technical, video about the 16v aux lithium battery for those who have it in newer Teslas. The video has timestamps for easy access to pertinent information. Of most interest might be: 1:50 The jump-start terminals of the Model 3 2:18 Owner's manual...
teslamotorsclub.com
