Are you presenting Hawaii as an analog to a Mars colony?What do you call a place that:
I'm commenting on a resident of Hawaii poo pooing other people making a colony on Mars.Are you presenting Hawaii as an analog to a Mars colony?
plus look at the increase in renewables (solar/wind)I'm commenting on a resident of Hawaii poo pooing other people making a colony on Mars.
He was making a joke, his actual proposal is to make artificial suns over the poles to melt the CO2 ice:Didn't he once advocate terraforming Mars by setting off H-bombs there?
Elon Musk elaborates on his proposal to nuke Mars
He wants to create two tiny pulsing suns over the Martian poleswww.theverge.com
There're also proposals that doesn't actually use anything nuclear to get the same effect:
How to terraform Mars for $10b in 10 years
Part of the series on common misconceptions in space journalism. A follow on from a previous post on terraforming. As far as terraforming goes, I’ve recently been much more occupied with my startup…caseyhandmer.wordpress.com
And I would suggest you read a bit more literature about the whole thing before concluding it's "impossible", a lot of clever people have thought about this in depth.
Read the full article for more details.Perchlorate on Mars: a useful resource for humans
The ClO- ion consists of a central chlorine atom surrounded
by a tetrahedral array of four oxygen atoms. Owing to its
strong oxidizing power at higher temperatures, ammonium
perchlorate (NH4ClO4) is predominantly used as an energetic
booster or oxidant in solid rocket fuel. The most beneficial use
of ClO4−on Mars would be as a source of O2
for human consumption and to fuel surface operations. For example,
humans breathe or consume 550 litres of oxygen per day.
Based on the amounts of ClO4− measured in Martian regolith, a
daily supply of oxygen for one astronaut could be obtained by
complete dissociation of ClO4− contained in 60 kg of regolith
(40 litres). More importantly, mining out oxygen from ClO4− in
Martian regolith could be done cleanly and with minor
alterations to the regolith, taking advantage of existing
microbial biochemical pathways for perchlorate metabolism.
It has been known for several decades that some micro-
organisms can reduce ClO4− under anaerobic conditions, and
more than 50 dissimilatory perchlorate-reducing bacteria have been isolated in pure culture
The point is, yes Martian perchlorate is certainly a very serious issue but there are potential ways to address the problem.Once the oxygen was extracted, the regolith could be returned
to the surface free of ClO4−, and in the case of ground ice, the
water would be suitable for human consumption or food growth.
As for the cosmic ray shielding, that problem has to be solved regardless of the propulsion method. I was simply pointing out how nuclear propulsion doesn't have as many problems as initially thought.
I too think a Mars colony is a bad idea, but I am in favor of a space colony and diversifying our habitable space. Relying on earth alone is short-sighted.
Astronauts survive in space stations for months at a time. The air is 100% recycled, while the water is 98% with solar panels providing the energy to do all this. The cargo ships supply mostly food. Granted that still leaves quite a bit to solve, but I'm hopeful by nature. After all, the earth is also a closed ecosystem with nothing more than energy from the sun to drive everything.
I get the point. However, you could make the Earth a perfect paradise and work very hard to adjust human behavior to clean everything up. None of the would prevent a comet, asteriod, or some other object from striking the Earth and wiping everything out. Let alone some wacko nutjob dictator from starting a nuclear war or some angry teenager from creating a worldwide virus that kills everyone. How do you prevent people from having children? We're getting close to 8 billion people on the planet. What are we going to do at 10 billion? 15 billion? You think we've got pollution now, then what are you going to have then? The world has problems. They will not go away.The ISS is in low-Earth orbit, well within the Earth's magnetosphere, and therefore protected from cosmic rays. Solar panels provide all the energy, but air and water have to be replenished as needed from the Earth. Food is rather important, and it all comes up from Earth. Also any needed medicine comes up from Earth. And an astronaut who has a medical emergency is just hours away from all the best medical care Earth has to offer.
Once en route to Mars, the astronauts are no longer within the protection of Earth's magnetic field, and are two or three years away from any but the most rudimentary medical care. If you or I get sick there are hospitals with labs equipped to do every imaginable kind of test, there are MRI machines and CAT scan machines and EKG machines and EEG machines, and a thousand other machines I don't know the names of. There are pharmacies with thousands of drugs immediately available. Mars astronauts will have none of that but maybe a couple of dozen drugs, a stethoscope, and a sphygmomanometer. And maybe a pliers for pulling teeth.
The Earth may be a closed ecosystem, but it's huge, and finely balanced (though we're working our best to unbalance and ruin it.) I honestly puzzles me that people think we could create a sustainable habitat on Mars when we cannot even preserve the most perfect planet imaginable.
Mars is not the salvation of the human race. If we want the human race to continue, we need to stop dumping poisons into the air and water; we need to stop dumping CO2 into the air, we need to stop acting like selfish, self-absorbed children and start working together to preserve what we have. Mars is a distraction.
I'm not hopeful.
Do you have an expected timeframe for solving the pertinent problems before we have a closed ecosystem that is independent of Earth?
This sort of thing is my primary interest in having significant spaceflight ability. The other big one is robotic exploration (so I'm a fan of robotics and AI).None of the would prevent a comet, asteriod, or some other object from striking the Earth and wiping everything out.
These are problems of our own making, and they deserve to be addressed before we start exporting whacko nutjob dictators and angry teenagers. It is the fact that we have been able to keep expanding that we have ignored our problems. We have always fled from our problems by just finding new real estate that is far from the people we disagree with. Now, the web has put us all in each others' laps, and that's one reason that society is getting so crazy these days - it's more difficult to hide from our problems.Let alone some wacko nutjob dictator from starting a nuclear war or some angry teenager from creating a worldwide virus that kills everyone.
Through social engineering. It happens everywhere. Some efforts in favor of higher birth rates and some in favor of lower (e.g. China's one child rule). The world population is expected to peak around 2084 at around 10.4 billion, and then slowly decline. It's a prediction, so take it with a grain of salt, but that's the current thinking. The point is that various forces in our lives make having children more or less appealing. Right now, people are apparently not having kids because of the need to work and the inability to find housing. Forces like that determine birth rates. We are more complex than bacteria, so there are a number of ways to influence whether we have children or not.How do you prevent people from having children?
The drive was never there. The Moon push was a prestige project to show that the west was superior to the Soviets, who were cranking out one achievement after another in space. Engineers and businessmen will always be interested in grand projects, but the nation as a whole was just caught up in "moon fever". As soon as Neil set foot on the moon, people were done with the whole thing. Including Congress, who defunded the program, despite having flight hardware ready for additional missions, and ambitious plans from people like von Braun.But the drive is no longer there, and there's this cultural aversion to risk. People aren't willing to risk their lives for years at a time to build a space colony.
I can guarantee you that there are thousands of highly qualified people who would gladly volunteer to do just that. If I was 30 years younger and single I certainly would.People aren't willing to risk their lives for years at a time to build a space colony.
... if you want to humanity to continue to expand and grow, ...
With the right tools, the universe is an unlimited resource.Why should humanity expand and grow? A species is successful when it can live and endure within the limits of its resources.
See, I disagree that we could make the Earth a perfect paradise. It WAS a paradise, and WE are the reason it isn't anymore. We have gotten so good at reproducing that we've become a cancer: A thing that grows out of control and kills off the rest of the organism.
Why should humanity expand and grow? A species is successful when it can live and endure within the limits of its resources. Success for humanity, IMO, would mean learning to live within our natural resource budget, while allowing the rest of the natural ecosystem to thrive as well.
Off-planet colonization is a pipe dream because no other place has the resources humans need to survive.
I don't see a reason for putting people into space. Just as we're on the cusp of being able to build habitable space stations by using tools like Starship, we're also on the cusp of having advanced robots and AI that won't need space stations. We've had robots on Mars for decades for a reason - they are designed to be there.
Far more people apply to be NASA astronauts than there are spaces available. That has always been the case.
Humans are explorers. It’s how we permanently occupied 6 of the 7 continents just by walking into the unknown. Multiple nations have human space programs right now and they will continue to push the envelope of what is possible.
For those who aren’t interested, fine, stay home.
You appear to believe that human civilization on Earth is doomed, while at the same time believing that there is zero chance that human civilization could be established off Earth.
I suggest you gracefully withdraw and let the rest of us who want to discuss the possibility of off Earth colonies continue the conversation.
Thank you.
