First time supercharging on the latest firmware, and I saw a pretty steep taper kick in much sooner than on previous versions. Used to hold 115 kW to 30%, this time it began dropping shortly after I connected at 20%. Good news is that the handle did not overheat, and there was no abrupt decline to 60 kW as experienced by many (including myself). Taper seemed consistent with prior experiences after 40%. Are other 85s experiencing this as well on the latest firmware?
FW: 17.34.xxx
Max battery temp: 42 C
Both front louvers actuated, and the condenser fans began running at a low speed about 10 minutes after I began charging. I conclude, therefore, that the battery was not thermal limited.
Data attached below. Black points are from previous firmware collected anywhere between 2 years ago and 3 months ago. Red data points are from the most recent session where I experienced the early taper.
FW: 17.34.xxx
