My solution for busy superchargers
cpa
3,833
5,987
Central Valley
Bear with me here, trying to post a photograph, and it is a struggle:
Thought I would use this ad hoc method until Tesla develops a solution for clogged Superchargers.
I would not use this at sketchy isolated locations like Kingman or Quartzsite, but popular ones like Rancho Cucamonga, Oxnard or Ft. Tejon seem to fit the bill.
This way, newcomers will have an idea when I will return and the stall will be available, or will know not to use the paired stall if my return time is 30-40 minutes away, and there are other stalls.
the only real solution is for tesla to update each car to show how many stalls occupied/not occupied at each SC location.
that, and build more SC's of course
I don't know that this will really help that much, because presumably you'll be making the decision about going to or skipping that supercharger two hours before you actually get there, and the backups are likely to be transient in nature - especially if everyone else sees the backup an hour or two ahead and tries to dodge it (this leading to an unforseen backup at the next Supercharger down the line.)
The only way I can see to effectively avoid it is to have some knowledge of what level of traffic is coming in the future - which might not be as impossible as it sounds. If Tesla rolls out an updated road trip navigation package that incorporates guidance through Superchargers, it could talk to a central computer when you start driving the route and make 'reservations' for you.
The Superchargers would still be first come first served, of course - but if most of the cars have plans laid out, the central computer can start to see where the capacity pinches, and suggest alternatives like a traffic enabled nav system does.
Ideally, the road trip Nav update would also give you charge needed for the next leg (based on driving it at your speed limit alarm offset and real time weather and elevation,) and possibly even an estimated time to charge when you plug in.
Walter
This way, newcomers will have an idea when I will return and the stall will be available, or will know not to use the paired stall if my return time is 30-40 minutes away, and there are other stalls.View attachment 65432
This is brilliant! So simple.
I'd assert that a majority of present and future Tesla S,X and 3 owners will have absolutely no idea about the charger pairing issue until the car tells them exactly what to do.
You are indeed correct, HLR. I was at Ft. Tejon on my way home on Saturday, and I noticed that three arrivals during my charging session gravitated to the mated stall of another car that was charging. I ambled over to speak to the drivers, and all three were unaware of the reduction in charging speed. One acknowledged that she had noticed that sometimes the charge rate was slow, and figured there was some defect in the system, so she would move her car. The second driver had the information backwards, saying that you WANTED to use a matched charging stall. The third said that he always just plugged in for an hour to go eat and would take whatever electricity was available.
The sales staff and the Delivery Specialist need to make this information a priority for all new owners. Many new owners will take delivery and not use a Supercharger for many months until their first road trip. By then they more than likely will have forgotten this important information. A small laminated card with tips and tricks (and a reminder that drivers can change the charging information from miles to kW) might fill the bill until the software gets up to speed to direct the driver to the appropriate charging stall.
The issue is that it's difficult to predict how much time I will need to charge. I might plug in as a second car on a shared spot and then the other one leaves. Or the other way around. After having charged at SC 50 times I still don't know really how much time it will take to go from 23 miles to 190. Even Tesla isn't giving us an estimated time to finish charging when charging at a Supercharger because there are many unknowns.
The idea of a networked navigation giving the diver predictions and redirecting will also never work as the majority of people don't use their navigation system so the car doesn't know where you are going. The only solution to full Superchargers is to have more Superchargers. Not adding more stalls, but more locations.
The only thing we can do is be considerate and use the Superchargers only when we need it and only spend as much time as we need.
@cpa - great idea. Beats leaving a note on the dash.
The ChargePoint phone app does show all their chargers and which ones are not occupied. Handy when coming to an area where there are multiple charging locations. Not the case with Superchargers. Although, it would be nice if there was some of that technology available for us as we head into Superchargers to know that there may be a wait.
Not really...here are screen shots with AC charging and Supercharging. The AC charging has time remaining, but the Supercharging does not.
View attachment 65485 View attachment 65486
There are a couple reasons for this:
1) the supercharger "curve" is a lot more variable - it declines based on how full the battery is (although this is very predictable) and it can also vary dramatically if someone plugs into the paired supercharger next to you.
2) the AC charging, on the other hand, is assumed to be a very constant amount of power - there's almost no such thing as "shared charging" when plugged into AC power. Plus since the max you can realistically provide to the car is about 19kw, the car battery can take this much power until it's very very close to 100% full. This makes calculating the finishing time a lot easier.
I'll also contend that Tesla doesn't really want to show how much the charge rate shows down as the battery fills up, but hey, that's my bias. If you want an accurate reference of "how long it will take to get from charge level A to charge level B" on a super charger, that data is in the spreadsheet linked above.
Totally agree. Is there a reason that they can't show the SC's available space?
What I'd like to see are simple Green, Yellow and Red lamps on the top of each Supercharger stall.
Of course:
Green: Full Charging available
Yellow: Split/Shared Charging available
Flashing Yellow: Split/Shared Charging available, but very limited (due to other car pulling a full charge)
Red: Inoperable
Of course:
Red: Inoperable
Yes please!! I lost count how many times I switched spots on a SC only to get the best charging speed.
Except for an OA, I've yet to meet a a Tesla employee who's also an owner. Based on conversations with some employees, this appears to be by design.
Letting a DS drive a MS for a week during training is way different from an owner's every day carry perspective. Maybe that'll change once the CPO program kicks off.
But to be honest, I've never met a Toyota, Lexus, BMW, MB or Audi sales/service employee that was also an "enthusiast", for that matter.
Thanks for the idea. Ordered one just now.
As the SCs are getting overcrowded nowadays, I find myself driving in only to turn around and leave because of the long lines. This is something that Tesla needs to address. I've had some close calls with having enough range to get home, so having to reroute wastes quite a bit of energy had I known the line up at Tesla
