Mystery Problem! Left rear window
Horrible said:
Well, I finally got the regulator,$230.00 plus tax !
I installed it. Then moved the door panel closer so I could connect the switch wires to make sure the window worked and it did.
Connected everything else and installed the door panel.
Closed the door to reset the switch.
That’s when I noticed the door handles didn’t pop out when I touched them. Now what?
Luckily I had the window down so I could get in.
When I tried the window it didn’t work! Nor did any of the other windows!!
I did a reset with the scroll wheels. No help! Also turned all power off. Still no help!
Tried the driver side door handles again and they didn’t move but I discover the handles on the passenger side were working as they should when I touched the handles on the drivers side???
I called the Tesla 800 number and 45 min later they answered the phone.
They checked everything they could on their side and told me everything looked good!
Guess I’ll be going to NOLA SC.
Worn wires in harness that come out of the door and into the pillar?
Don’t know!
Fuses checked good.
Their was plenty of movement to get the regulator out but then again the window worked fine before I put the door panel on.
Why would the drivers window and the door handles stop working?
I discovered the right side windows work but not from the drivers seat.
So it’s the left side that’s inop,
Except for the mirrors. Both sides fold and extend??
Here’s the thread
