pwrusr Member Dec 4, 2019 62 5 socal Feb 8, 2024 #1 Feb 8, 2024 #1 Hello! I am running the following lowered -5 front and -6 rear links 20x10 +30 / 20x11 +32 265/40/20 / 295/35/20 Do I need to run rear camber arms/shims?
SignatureSales Member Global Vendor Jan 25, 2019 990 1,804 California Mar 19, 2024 #2 Mar 19, 2024 #2 pwrusr said: Hello! I am running the following lowered -5 front and -6 rear links 20x10 +30 / 20x11 +32 265/40/20 / 295/35/20 Do I need to run rear camber arms/shims? Click to expand... Your rear fitment is pretty spot on. Rear camber arms or shims are not required, but opting for either can help extend tire life. Shims would be a cost-effective option. The silver EVPE shims in this case will be ideal for your wheel setup. N2itive Camber arm option is also avalbale if you prefer full range of adjustment.
