I got mine from the Facebook marketplace for $400and mines gone up in value since i bought it LOL i got it for 499 and i think now they go for like 800 bucks
That's why I bought the optional tow hitch pkg. A short guy like me will have difficulty putting our 2 ebikes inside the Y if it even fit. I have yet to haul our bikes with the Y.I'm getting a MY with tow package on Friday and plan on using it for my two eBikes. My rack is 46 lbs and my eBikes are 62 and 65 lbs, bringing the total weight to 173 lbs. But my eBikes also have 8.5 lb batteries, which I will always remove before loading the bikes. The 17 lbs will bring the weight down to 156 lbs, which is just below the 160 lbs. I personally think the 160 is a conservative number and there is no way I would ever attempt to load those two beasts into the back. Not only because it would be extremely tedious and frustrating, if even possible, but because I am certain both my bikes and Model Y would get damaged.
Also, some eBike locks can get over 5 lbs, so keep those in the back of your car while transporting. You are fine locking up the bikes when parked, since weight related damage will typically only happen when you hit large bumps, etc.
I will have difficulty putting those heavy ebikes inside. That's why I bought the optional tow hitch. I use a ratchet strap and light weight cable/lock when hauling em. I use the heavy motorcycle chain-lock when using public bike rack. Yes, that chain is heavy. So as the batteries. Just like you, I put them inside the vehicle. I have yet used our Y hauling the ebikes.I'm getting a MY with tow package on Friday and plan on using it for my two eBikes. My rack is 46 lbs and my eBikes are 62 and 65 lbs, bringing the total weight to 173 lbs. But my eBikes also have 8.5 lb batteries, which I will always remove before loading the bikes. The 17 lbs will bring the weight down to 156 lbs, which is just below the 160 lbs. I personally think the 160 is a conservative number and there is no way I would ever attempt to load those two beasts into the back. Not only because it would be extremely tedious and frustrating, if even possible, but because I am certain both my bikes and Model Y would get damaged.
That's a goodThis is my setup with a 1UP USA "Super Duty Double" rack. I love the rack but am concerned with the lack of visibility to my brake lights when both bikes are installed. I don't want to get rear ended and, if it happened, don't want any insurance disputes do to the lack of brake visibility. I ended up ordering an adhesive LED strip for brakes and turn signals, which I will place onto 1UP's e-bike ramp accessory that installs on to the lower two bolts. The LED lights will then connect into Tesla's 7-pin connector.
I ordered this adhesive LED strip, along with a 4-pin to 7-pin adapter and cable/wire organizer:That's a good. Do you have the link for the LED strip? I might also install a rear license plate holder.
well, there's still the possibility someone made the kilo/lb error on the first doc on the US page and then the next person propagated it.On Tesla's Canadian site they give the weight in kg (72) so I do not think it is a typo. Tongue weight (straight vertical load) is very different from a cantilevered weight from a bike rack.
Ah! I had that with my truck. It was bright and easy to install. I never thought to use one on my rack until I saw your post. TyI ordered this adhesive LED strip, along with a 4-pin to 7-pin adapter and cable/wire organizer:
Your bike rack will need a good place to display it, however. I fortunately have a removable bike ramp that will be perfect on the back end. 1UP also makes a brake light attachment, but thought it was too pricey at $200+.
It's simple with bike racks. Most especially if the bike rack is very light. If the rack is heavy, then you might need assistance. Tops, depending on the setup, you would be done in less than 15 minutes with 2 bikes. Another 15 mins to unhook the bikes, the bike rack.Is the tow hitch thing user friendly or do you need to be experienced? Tow hitch seems like a cool idea but I don't know how long much time I will have to invest each time to put that thing on.
The Kody Lightbar with a quality mount is pretty nice: https://www.kodytechnologies.com/product-page/1upThis is my setup with a 1UP USA "Super Duty Double" rack. I love the rack but am concerned with the lack of visibility to my brake lights when both bikes are installed. I don't want to get rear ended and, if it happened, don't want any insurance disputes do to the lack of brake visibility. I ended up ordering an adhesive LED strip for brakes and turn signals, which I will place onto 1UP's e-bike ramp accessory that installs on to the lower two bolts. The LED lights will then connect into Tesla's 7-pin connector.
no issue. Multiple stops at SC having two ebikes. My bike rack is 1up using a hitch extender so it sticks out more.Will it be an issue using a supercharger station while the hitch bike rack mounted? Mine sticks out approx 34" from the rear bumper. So far I've only used SC twice and never paid attention to the rear clearance. I hope the charging cable is long enough. Otherwise it would be a pita to dismount the ebikes and bike rack.
Agreed here. Believe the correct tongue weight is 350lbs. I saw this in several places before deciding to ordering my Model Y with the tow hitch. As the primary reason I will use it is to carry 1 or 2 bikes.you prob can but i actually believe the true weight limit is 350 i believe tesla made a mistake writing it as 160kg to 350 pounds total seen plenty of model Ys with two 65 pound ebikes on the hitch no issues.
Too much work putting the ebikes inside rather than using the bike rack. The only disadvantage of using the bike rack is affected range. Been using my MYLR since March with two ebikes. No issue from my recent MTB trip from San Diego to Palm Canyon trails.
No issues getting the XTR Pro 2 on the car? I’ve been using mine 2 years for various ebikes. Sometimes it’s easy, sometimes it takes many tries. And yes I’ve tried lube! I think it’s visibility + alignment.and mines gone up in value since i bought it LOL i got it for 499 and i think now they go for like 800 bucks
That purple bike…Too much work putting the ebikes inside rather than using the bike rack. The only disadvantage of using the bike rack is affected range. Been using my MYLR since March with two ebikes. No issue from my recent MTB trip from San Diego to Palm Canyon trails.
