New battery with lower range and BMS error
Hi
I have a Model X 2020 long range plus that just had a new battery.
I think I'm going mad as before replacement I think I remember getting ~351 miles range and now with the new pack I'm getting 319.
The car also never charges last 99%.
I've done the discharge, charge to 100, leave plugged in a few times but no fix.
I did a Tesla Scan and also in service mode I get an error.
Maybe I'm going mad and the range was always below 320 (we only had the car 2 weeks).
Attached is the battery info, Tesla Scan and BMS error.
Any advice ?
I see you now have a useable remaining pack energy level of 84.1 kwh. Were you wise enough to record your useable on your, now failed, original battery?
I just had my in warranty 2016 90 kwh battery replaced under the 8-year warranty. I was prepared for that scenario. I kept track of my original battery energy level, 69 kwh useable. I expected Tesla to supply me with a remanufactured battery capacity of 69 kwh or greater. When I picked up my car, while in the parking lot, with my service advisor nervously watching, I checked the "new reman" useable capacity. 70 kwh indicated, Tesla met their warranty obligation to meet or exceed original battery capacity. Case closed.
Did you do the same?
Reactions: Rocky_H
Unfortunately not. I only had the car 2 weeks so wasn't expecting a failure. I can only assume that they replaced with the same or larger Kwh.
Hi
Any advice ?
If you have the readouts from the old pack go back to them. And it seems they did not performed the 2 routines for pack repalcement (available in Service menu + on MCU2 after connection to Toolbox 3).
