I'd say change is interesting and worthy of discussion from a technical standpoint. The only thing "upsetting" to me about this change is the FUD we are likely to see from certain sectors because of it.
It's a PMAC motor. The technology is very similar to that of Emrax, which claims to be getting even more power per kilogram than Siemens. Everyone working on aircraft motors that I know of is using PM -- unless they're doing research on superconductor-based motors running at cryogenic temps . . . maybe for mid-century airliners.Siemens has been able to squeeze 5 kW/kg out of their aircraft motor, but I can't find anywhere whether it's a permanent magnet or induction motor. Obviously this is designed first for weight, and performance and efficiency are close seconds.
Siemens Unveils 260 KW Electric Engine
Yes, 76 kg is the weight of the full Bolt EV drive unit which includes the motor, reduction gearing, and FWD differential.plus 7 liters of transmission fluid.Edit: I didn't expect to find anything on the Bolt yet, but I was surprised to discover this article, which says the (drive unit?) total weight is 76 kgs (~170 pounds), for 150 kW output. Much closer, but still not equalling the Tesla Power to Weight, let alone exceeding it by 40%...
I wasn't clear on which variant of Model S that rear drive unit was from. If it was from a regular RWD S then the motor is rated for 285 kW, I think.For comparison, the author of this post claims in a comment that the complete RWD S drivetrain weighs 135 kg (302 pounds) - and that includes the drive inverter, which isn't a part of the 4ET50 weight, as well as the motor, gears, and differential (and the Tesla hits 2x the max combined power of the Volt motors in the Performance versions.)
They likely just made an assumption.Not sure what to make of it, but according to the Car And Driver: "The Model 3, like the Model S, is a rear-wheel-drive car in its base form, with a rear-mounted AC induction motor"
The older article Charged EVs | Tesla’s chief motor engineer discusses the potential of next-generation motor technologies
pretty much gives away that they are using magnets.
I am just looking at the evidence...I would not dismiss Car and Driver's statement so easily.
Note that EPA document has other information that is questionable, for example battery specific energy at inexplicably high 150Wh/kg. So it is possible that EPA document, rather than Car and Driver is wrong.
As far as I am concerned, the jury is out on this.
He was attending a conference on motors. I would not expect him to focus on Tesla unless asked.
- Then the Chief motor designer at Tesla answering a question about motor costs speaks immediately about magnets without being prompted.
TrueHe was attending a conference on motors. I would not expect him to focus on Tesla unless asked.
For example, we were going to start off with dual motor. But that’s like wait a second, we just doubled the probability of something going wrong if we got two motors, because there are two different motor architectures. One motor is optimized for highway travel and one is optimized for stop and go traffic, which is great for maximizing your mileage in city and maximizing your highway – your mileage on the freeway and having incredible acceleration. But it’s too much complexity right off the bat. So we will just be single motor to begin with and then we will have the dual motor config
Interesting, makes it sounds like in the dual motor version there will be one of each type, one PMAC and one AC induction. Plot thickens...I dont know if this has been mentioned earlier in this thread, but Elon said this in early June this year (Annual Shareholders Meeting Conference) about the Model 3 AWD motors:
I didn't read it that way at all, just that the motor firmware for AWD is more complicated.Interesting, makes it sounds like in the dual motor version there will be one of each type, one PMAC and one AC induction. Plot thickens...
