Yea, that wasn't available to normies when I posted this way back when. I'd like to think they plagiarized my work. LolThe is a full DIY on all models how to replace the onboard charger on tesla service website. You need to create and account and there you can find a complete how to.
I dont think that this should be a problem.Yea, that wasn't available to normies when I posted this way back when. I'd like to think they plagiarized my work. Lol
You think it's ok for us just to post the pdf here? Not sure if it's against the rules or not.
Made an account to say that your post was immensely useful, thank you. I would not have attempted to try this had it not been for your trial and error. I want to also to share my experience in case other people run into the same problems or are trying to diagnose their charger.Here is my experience replacing my onboard charger on my 2017 Tesla MS75D.
Disclosure…
Don’t try this at home, YMMV, High voltage, you can kill yourself if you do something stupid, yadda-yadda, I’m not liable if you do this, warranty void, blah blah blah…
My car specs:
Symptoms:
- 2017 MS 75D (USA)
- Gen 3 charger
- Part # 1052532-00-D Rev01
- >ADC12< 113492 XS 1-1
- XS 2-1 WILL NOT WORK IF YOU’RE REPLACING XS 1-1
- 48amps – Single Charger
So, I could have kept limping along at 24amps (50%) until it gave out all the way, but that doesn’t seem right to do that on a 5-year-old Tesla.
- While using Level 2 chargers, my amps would jump around from 0-24 and then settle at 24 amps
- Tesla Mobile Connector capable of 40amps
- Multiple errors including:
- Unable to charge, check charging equipment
- Unable to charge, disconnect cable and retry
- Charge speed reduced, unplug and try again
- Notice how it never blamed on the on-board charger???
- This software oversight was disappointing
- How hard would it be to just say, “Your onboard charger is half-broken”?
- I tried charging with my wife’s 1772…no change
- Took it to a Tesla Destination charger (48amp capability) and it did the exact same thing
- Voltage never dropped during charging
- IMO, this ruled out a faulty charging port, which was replaced 18 months ago.
- Supercharging unaffected
First off, these don’t have the troublesome 50-amp fuses from Gen2 chargers. That was my first mistake. After removing the back seat, I could immediately see I had a different/newer charger.
Part # Warning
I bought a charger off EBay from a project car guy. (integrityholdings) He had a stack of them and was unloading them for $300. Unfortunately it was the XS2-1 instead of XS1-1. I didn’t think anything of it and put it in. Tons of errors. I tried to redeploy firmware but it failed. I can only assume the XS2-1 is a slave from a 72amp dual charger setup. I got a hold of the seller and he was able to find an XS1-1. Restaged firmware, swapped charger, installed firmware, and all was good. Charging at a full 48amps now. No issues!
Tools Needed
Part 1 - Pre-Setup and Software Staging – Your car won’t be driveable if you don’t accomplish these procedures first!
- Torx Bits (T-20 – T-30)
- Sockets (Metric)
- Screwdrivers
- Multimeter for checking High-Voltage (600V rating)
- If you don’t know how to use a multimeter for checking AC/DC voltages, you probably should stop here.
- Electrical gloves
- Wife to hold up coolant lines so they don’t spill everywhere
1. It’s almost guaranteed you’ll need to flash the firmware on the new charger after you install, so you’ll need to have a software update pending before you start the replacement
2. Go to a Tesla Service center or approved body shop (most body shops work but not all)
3. Push and hold on your Model in the Software Screen, let go after 5 seconds
4. Enter “service”
5. Remove speed limit
6. Back out of menu
7. Pick “Software Reinstall”
8. Pick “Full Reinstall”
- Partial Install probably works, but why chance it?
9. MCU will eventually show a software update is available.
- Could take up to an hour
- Do NOT install yet!
- Leave car in “Service Mode” just in case
10. Drive home
11. Ensure software update is ready to be installed before proceeding
Part 2 – Replacing Charger
1. Move driver and passenger seat all the way forward
2. Roll down windows and open all doors
3. Take pictures along the way, to help with re-assembly
4. Remove frunk…
-View attachment 770649
5. Disconnect 12V battery (negative terminal only) and fireman’s loop
6. Charger is located under rear bench seat
7. Pull up on the front part of the seat. There are two retaining clips that you’ll probably break in doing this. The only way to get it out without breaking them is to use a flat head screwdriver. I couldn’t get it, so I just pulled up hard on the seat. I’ll order more later.
8. Disconnect seat weight sensor connectors…3 of them
9. Remove side seat small pieces by pulling at the top, toward the front of the car. They should pop out.
10. Remove seat backs starting with the larger one. There’s a rod that connects them at the hinge point. You have to pull the seat toward the door to get it out.
11. Remove 8 bolts to release the cage. (Large Blue "Remove" is the seat trim piece that comes off in step 9.
12. Cage has one cable running to the frame of the car. Disconnect before removing cage
13. Remove cage to access the charger
14. Pull Blue PTC plug from charger
15. Red clip needs to be pulled to unlock it
16. Put on electrical gloves
17. Open small lid of charger to access 4 HV terminals (T-20 Torx screws)
18. Check terminals against chassis ground for voltage (AC AND DC).
- If more than a couple volts are present, STOP and make sure you disconnected 12V battery and don’t have your car hooked up to a charger.
19. Disconnect ground cables (2 of them) from charger (1 is Torx, 1 is a metric bolt)
20. Disconnect:
- 4 orange HV cables
- Nuts on input cables
- Torx on output cables
- The black retaining clips are a pain to release…use flat head screwdriver
21. Disconnect communication cable from far side of charger
- Red clip needs to be pulled to unlock it
22. Remove two bolts and two studs holding charger in place
23. Place towels under coolant lines
24. Get someone to hold coolant lines up
25. Disconnect coolant lines using pliers to release clamps
26. Plug coolant ports on charger if you have plugs, otherwise be prepared to make a mess
27. Remove charger and install new charger
28. Install coolant lines
29. Release Wife or Husband to go back inside
30. Reinstall ground cables, HV cables, comm cable, PTC Blue plug, etc…
31. Reinstall cage, rear seat, seat sensor cables, etc…
32. Connect Fireman's Loop and 12V battery
33. Errors will mostly likely pop up
34. Start firmware update
36. Cross fingers and get a drink (this will take a while)
37. Reinstall whatever left over pieces you have.
If all went well, congrats on saving $2500+
can you send a picture of that charger?Thanks to dbldwn02 for his work and all the other people here. My situation is a bit different but still want to seek advice here.
I moved to Spain and brought my 2015 S with me for relatively low mileage free SC and overall very good shape. All the EU mods were completed but somehow along the way the phase 1 on the master charger failed (this makes it impossible to charge at 220V outlet or monophasic wall charger). Could be during the mods or just because it was the time. Tesla in Spain refuses to work on US cars that were modified (they don't do the mods so is BS), on charging issues, everything else they would service. They would also sell me the gen 2 charger. Looking at this and having computer engineering background, I could probably do it, however honestly I'm hesitant as I would not be able to go anywhere if the car is bricked. Ideally I would like to change the fuses in the gen 2 charger to avoid messing with everything else. Also I was under the impression that the charger will have to be programmed as master no?
I spent countless hours searching on how to replace the fuses in the gen 2 charger, however I could not find anything, even though everyone says you could (including dbldwn02). To add to the frustration I have seen a gen 2 open and all is glued in, was not sure what could be done or where the fuses were. Also searched for a place to do it for me but couldn't find anything in Spain.
Anyone could offer advice please?
Thanks!
Yea, pictures are worth 10,000 words when dealing with Tesla chargers. Haha.can you send a picture of that charger?
Actually Im pretty sure thats gen2, Tesla is telling me I can still change fuses, need to figure out how…That's a gen 3 charger. What's the part number on the lid? Looks exactly like mine. 2017 MS.
No fuses to replace. You went way farther than I did. It just sounds like one of the three modules is bad. I don't ok now anyone who has replaced a module.
It looks exactly like the inside of my gen3 charger. If you provide a pic of the lid or a part # of the unit you have (not the unit Tesla says you have) I could tell you for sure.Actually Im pretty sure thats gen2, Tesla is telling me I can still change fuses, need to figure out how…
I just spoke with the guy who made the EU mods. He confirmed is gen 2 what i posted and what I have. What fuses I need model etc? I cannot stand Tesla for refusing to work on my car, and I have been supporting them since 2014. I still do although my respect goes to Tesla to all people working there not just one guy…It looks exactly like the inside of my gen3 charger. If you provide a pic of the lid or a part # of the unit you have (not the unit Tesla says you have) I could tell you for sure.
I can say for sure you don't have user replaceable fuses so you can give up finding those. Also Tesla doesn't replace fuses. They usually replace the whole charger and send it back to the factory for refurb.
The two 50amp fuses in gen2 are very easy to get to.
Yup. You're in a tough spot.I just spoke with the guy who made the EU mods. He confirmed is gen 2 what i posted and what I have. What fuses I need model etc? I cannot stand Tesla for refusing to work on my car, and I have been supporting them since 2014. I still do although my respect goes to Tesla to all people working there not just one guy…
I don’t think those videos are for gen 2, found out they were all about gen1.There are YouTube videos on getting to the gen 2 charger fuses.
Also wanted to say the OP helped me. I too had my 12v run out and needed to sit it on a tender over night and then I had to get all the bubbles out of the coolant else it would stop charging randomly at different intervals (longest charge first thing each morning).
Faulty Onboard Gen 3 Charger
Six months ago my MS 75D started charging at half the speed on a wall charger, it would only go up to 24 amps instead of 48. Yesterday it stopped charging entirely - it would charge a mile or so, drop to 23 amps and then eventually to zero. It would happen 3 or 4 times and then error out. I...teslamotorsclub.com
You're gonna keep saying that without sending a part #? Or photo of the lid?I don’t think those videos are for gen 2, found out they were all about gen1.
