Daytonaviolet
Hmm .. I removed the qyt8 10mm bolts by the front grille. The two visible bolts on the headlights. Lastly I removed the MX fender flares, fender splash guards and the T10 torx. Some cars may have a 8mm instead. Basically i followed the service manual but I didn’t remove the bottom 10mm bolts. I didn’t feel like the entire bumper needed to come off.@Daytonaviolet when you removed the bumper did you do a full removal including all electrical/sensor connections? Or did you just remove the portion you needed to expose the headlight bolts? If you have a YouTube video you used that would be great. This is for MX.
For safety, I did remove the LV battery connector as well as the first responder.
