Ended up upgrading to KW V3s
No issues.
COILOVER FEATURES
-Full Length Ride Height Adjustment
-32 Damping Adjustment Levels
-Mono-Tube Damper Design
-Seamless 52mm Electroplated Carbon Steel Shock Body
-O.D. 20mm Piston Rod For McPherson Suspension
-O.D. 14mm Piston Rod For Non-McPherson Suspension
-Unique 44mm High-Flow CNC 6061 Aluminum Piston
-Unique Thinned CNC 6061 Aluminum Floating Piston
-Polyurethane Oil Seal
-SAE9254 Cold-Wound Spring
-Multi-Thickness Valving Shims
-Unique Low-Gas Pressure Design
-7.5w Compounded Suspension Fluid
-Fully Rebuild-able-Wound Spring
-Fully Rebuild-able
