It will be on the news soon!Damn so they were right about the expansion, do you have pictures of the actual place being full?
Took less than 5 hours to be proven wrong. Impeccable timing!I'm completely baffled by this expansion. This was already not well located as far as amenities, or even geographically along this travel corridor. I have also never, ever, ever, ever either been at this Supercharger (5Xs there live) or when I check it on the nav (100s of times) seen this Supercharger close to full. 20ish stalls full was as full as it's ever been.
Baffling!
You are right, but my wife & I look forward to having a Blizzard while we charge. Those are getting expensive, but hey...it's the middle of the desert.Dairy Queen isn’t considered as good food for the most part lol
Ice cream is alway good.You are right, but my wife & I look forward to having a Blizzard while we charge. Those are getting expensive, but hey...it's the middle of the desert.
My policy is if you use the restroom of a business, you have to buy something.![]()
Driving home from LA to Vegas, getting there at around 2-3PM, yeah DQ sounds good about then.They going to need a lot more than restrooms for 100 charging cars. Dairy Queen isn’t considered as good food for the most part lol.
I've seen these before the last time I was through maybe a month ago. Not sure if/when they're active (probably just super peak travel times when it's >80% full) but when I was there, it was maybe 90% full and they had opened these up as "temp stalls" in a back row on that unpaved area like in the picture, furthest away from the freeway. Looks like they're still in the same location. I didn't use them so no idea about the rate but guessing the usual ~70kw. A couple were out of order but was about 5 chargers per truck (didn't realize there were a couple on the other side of the truck too) and they were mostly being used.Tesla Energy setting up for a busy holiday weekend. I've never seen these battery trailers before with V3 equipment but there are two of these at Baker.
That's less than 15 hours at max charging rate. But of course no one gets a continuous 250kW charge.Megapacks with V3 Superchargers. 3,000 kWh of storage per trailer with 250 kW charging. Nice.
I’m sure they are trickle charging off the grid/solar canopy so the standard 20That's less than 15 hours at max charging rate. But of course no one gets a continuous 250kW charge.
It can charge ~600 cars (probably more like 500 once you factor in losses and standby consumption) if the average energy added is 50 kWh per car. That’s a pretty good supplement to the network on peak travel days.
Wow, off by an order of magnitude! Thanks for the correction.600 cars is too good to be true.
3000kwh / 50 kwh = 60
