That actually looks like quite a bit of progress! Did you notice if the meter was already installed for the transformer? That typically is a key indication that they are getting close to being done.
Sorry but I’m not sure! These were sent to me. It sure does look like it’s going to soundly beat the Q3 estimate on the Tesla site.That actually looks like quite a bit of progress! Did you notice if the meter was already installed for the transformer? That typically is a key indication that they are getting close to being done.
Anyone in the area able to check on this one? I'm guessing we are getting close.
Interested in being able to cut time for a trip from STL to Des Moines.
Not yet got this response from hyvee management.Live?
Same with v2! It's been a while since I've seen one of the old v1s without the lights. I think they've mostly been phased out by now.A convenient visual indicator for V3 sites is the Tesla logo on the charging stands is illuminated when the stall is live and operational. This can be helpful even for existing sites to quick tell if a group of four stalls (one A-B-C-D) set is offline due to some issue with the cabinet supplying that group.
@Chuq @MarcoRP @corywrightThursday night, 6-11. Driving past the chargers they were lit up!
Plugged in but only got up to 84kw. So left it alone only getting 10 miles back lol Not on the network yet…
didn’t show up in my charging history either….
Whoops noted. My mind is gone@Chuq @MarcoRP @corywright
Please note: It's actually June 10th unless of course Chuq is the one to update supercharge.info![]()
Congrats!! We live in MSP and have family in SE Iowa (Ottumwa, Keokuk) so it's awesome to see this go live (along with Waterloo)!Thursday night, 6-11. Uhhh I mean June 10. We were Driving past the chargers they were lit up! So we Plugged in but only got up to 84kw. left it alone only getting 10 miles back lol Not on the network yet…
We stoppped and tried it!!! It’s live but we were then only ones there, and the KW were dropping…? Started high, but was down to 120. Maybe that was by design since we weren’t very low…Showing up on my map today, looks good to go.
You will see charge rate at a supercharger start high and then reduce throughout out the charge as the pack gets full, so what you describe of charge started high and dropping sounds totally normal.We stoppped and tried it!!! It’s live but we were then only ones there, and the KW were dropping…? Started high, but was down to 120. Maybe that was by design since we weren’t very low…
Anyways so nice To have this
Thanks for this. I’d wondered about it… I am learning.You will see charge rate at a supercharger start high and then reduce throughout out the charge as the pack gets full, so what you describe of charge started high and dropping sounds totally normal.
You'll likely only see max rates upwards of 200-250kW when your battery is down in the range of 20 percent or so. The shape of the charge curve has changed over the years and varies on different types of packs, but a general rule many use is a SOC + kW = constant type of a relationship. I have a mid-2016 Model S and do not have a first hand sense of some rough numbers for something like a newer Model 3 or Model Y..
