Thoughts on Medusa Black wheel covers for Model Y
The center cap is a cinch to remove and I apply the same method you describe. The hassle comes after the center cap is off.
With the amount of force needed to pull the cover off I have to wear work gloves or else the back edges cut into my hands.
I just use the trim removal tool there too, inserting it at the edge of the main cover where it meets the wheel and pulling out to get the first clip to release. After that the rest come off easily.
Those hub caps are designed for unidirectional rotation but then all 4 look the same. This mean, on one side of the car, they will be rotating in the wrong direction and create turbulence. This causes range loss. I had a similar set but then I replaced them with a set that has mirror imaged left and right sets.
How did you know what side you were ordering the second time? Did you got to their store?
Couldn't resist that 0.99% Tesla Financing offer and added a new 2024 Model Y in Stealth Grey to the collection.
Decided to go with the stock 19" Gemini wheels and added the new Rimetrix Medusa wheel covers.
Install was a breeze and took 15 mins to remove the previous covers, add the 7 foam adhesive strip protectors to the back of each Medusa cover, then attach the Medusa covers to the wheels.
Gives off that 20" upgraded wheels look since the covers are slightly larger than the stock Gemini covers.
Reactions: Royal27
Got several DMs asking for the price. Ended up being $239 + shipping with a $20 off code 31621MFQK that expires on June 13.
I replaced the Medusas with EVBase Induction lookalike and much happier. Not only were they cheaper, look just as good, but they're also just as easy to remove as the stock Gemini aero covers. Efficiency seems to be equal to stock aero covers as far as I can tell.
I really dislike the locking mechanism of the Medusas and they were a bear to pull off -- my set always felt like they were superglued to the wheels and would take 20 minutes of pulling to remove the set each time.
