Do you have your height set to a limited height for you home or work location? Mine is set to a lower maximum height for home but I can manually push it higher when the garage door is closed (which means more clearance height for the trunk door). Then, when closing from the full height position, it will stop at the lower/midway position which sounds the same as what you described.
