Vendor USB-C data issue on newer Tesla models: A potential solution
A number of Tesla owners since last December have taken delivery of their car with USB-C ports missing, or the data function of the USB-C ports gone.
If you found this to be the case with your new Tesla, and unsure what to do about the problem, this could be helpful.
For some new owners, it meant no wireless in-car charging for their phone. Some of the affected cars at least have some USB plug somewhere, which could be used for a conventional charging cable.
Many new Tesla owners felt like they were left in the dark and are understandably less satisfied than they should be. The reason for this snafu? The global chip shortage, for one. It’s a subject that’s been covered in loads of threads right here in TMC.
Was this clearly and directly communicated by Tesla well and ahead of time? Perhaps not, or not in the way one would expect from such a respected brand. And I won’t blame you if you’re one of the disappointed customers who received the late-model Tesla Models 3 and Y with the USB-C issue.
It’s unclear exactly how many new Tesla Model 3 and Model Y vehicles were delivered with missing USB ports or with data function disabled. These are brand-new EVs worth from $50k-$70k, so owners do rightfully expect a certain level of connectivity.
Here’s what we know so far: Cars that started getting delivered late last year had been affected.
We all love our USB-C ports. They’re quite a useful invention — a sort of Swiss Army knife of connectivity — data, power, and video capability in a small plug.
But sometimes, manufacturers remove one of the functions.
Was it really due to the chip shortage that made Tesla decide to remove the data function?
Whatever the reason — this missing USB-C outlet or data-removed-from-USB-C episode has become a fact of life for a certain batch of new owners.
It’s an issue raised by many. For one, if you want to use gaming controllers — it’s a no-go. Can’t be done.
Some solutions and then drawbacks
There are a number of solutions:
1. Get someone to retrofit your Tesla by adding a custom module — while this does restore data, there are a few drawbacks:
(a). The power they deliver is reduced from Tesla's original 27W (our testing shows 20W is the most common), which means some Tesla accessories, like hubs — won't work, due to insufficient power.
(b). Also, you can't trust that the modules will be compatible with future software upgrades, or future hardware in cars.
2. The second solution is workable: add data from somewhere else.
(a). This can be done — pretty easily — by getting our 3 Port USB HUB with DashCam Reader
https://www.jowua-life.com/collections/explore-all-products/products/3-port-usb-hub-with-dashcam-reader
(b). You get 2 additional data ports — and still can run the dashcam recorder with the dedicated microSD port on the device.
(c) Best of all, it's compatible with our Multi Device Wireless Controllers. That means 2-player gaming is back!
So it turns out that for every problem, a solution. Jowua has solved it for you.
Grab this device. It's $35 without SD cards, though there are a few bundles if you need one too. We’ve included a coupon code for TMC readers — so just use TMC5 when you make a purchase.
My supplier sending me this kit in place . I asked tesla for they say we will only replace with what’s in it . So I desided to other way and buy my own I guess
I just raised a service request to order the part number from my local service centre - gave them the part number, no questions asked and was available to collect within two days. I believe some of the very latest cars do not have the data cable installed (mine had it taped up on the wiring loom but I believe you can even still retrofit by routing a USB A to micro usb cable from the MCU to the USB hub location) For me it was a no brainer as it allows controllers and usb cards to be used without removing my sentry USB or having to put a hub in the glovebox.
Reactions: Solomon Mozi
Why bother with paying extra for a non supported module from TPARTS? Just buy the genuine Tesla USB C module from a 2020/21 model car and retrofit. That’s what I did in my early MY22 car which had non data USB - 5 minute job and the part is only £33 from Tesla. Picture attached showing the part number of the module and the additional USB cable connected (grey connector)
Did you buy it directly from them? How? It's not available on their online store.
Hello all, I just purchased the Abstract Ocean USB unit before learning about the Tparts version. I opened the cover and the USB cable was taped up to the power cable, so I was confident that I was good to go. However, no such luck. I connected everything and no USB data. I presume the data cable that runs from the center console to the MCU is missing. Does anyone have any specs on that cable? Tparts now includes that extension cable with their unit, but they are now backordered. If I had the specs (length and connectors on each end, I am sure I could source the cable on Amazon to avoid having to return the Abstract Ocean unit. Advice appreciated.
Great solution! What type of trim tool did you use to remove the panel to access the hub?
The USB issues in my M3P08 is the reason my next car won't be a Tesla.If they can't get code for a USB to not mess up all the damn time, how can I trust them to do FSD (which I have). USB (Universal Serial Bus) is a standard and sometimes working sometimes not behavior for over a year is wholly unacceptable.
It's certainly aggravating. I picked up my decontended 2023 M3RWD on 1/31. No USB data in the console, no mobile charger. Even the key fob I ordered had no batteries, just two empty CR2032 sized holes in a box that certainly cost more to manufacture than its contents. No spare, no jack, not even a can of Fix-A-Flat. I made a special trip to Harbor Freight to get a scissors jack, puncture repair kit and a lug wrench. And then there are the panel fits of a '70s era GM product and carpet last seen in a Saturn Vue.
That said, the car is a hoot to drive fast and I will be entertained for months learning the software. Would I buy another one? Probably not, there are so many compelling alternatives.
Those empty slots for 2032 batteries used to contain batteries. At least they did when I ordered fobs in December 2021.
Sometimes I think Tesla is eventually going to a BYOT model: bring your own tires.
Reactions: OldEvo
Oh, wait, I got distracted with my rant. I bought a TParts USB module that does not work so I am considering the Carrkoopy module. I've seen some conflicting information on its compatibility with the AMD Ryzen based MCU. Can anyone confirm the Carrkoopy works with that?
I wouldn't recommend the module (obviously). You never know if it will work with software updates. Hubs are safer.
How difficult is routing the cable from the MCU through the console? I just checked my model Y (10/2022 build) and I don't have the cable.
The most difficult part is removing the panel on the side of the console in the passenger footwell. It is fastened with 10 plastic "C" clips that have a pretty tenacious grip. There are several YT videos that show the process.
The panel underneath the glove box is easy to remove. The trick is to pop out the center button of the clips first and then the whole clip comes out quite easily.
After a number of vendor issues I finally cobbled together a working system with the Carrkoopy module and panel and the cable from the Tesplus kit. Now my wife has easy access to all 23,000 of her favorite tunes.
Knowing what I know now, if I had to do it again I would buy the Tesla module and cables.
I’m trying to buy the parts from Tesla right now but local service center refusing to sell them.
