Guys its pretty simple, if you have HW4 you do not have a USB port on the MCU. If you have HW3 then you have the USB port on the MCU. Regardless the center console ports will not have the data port module installed so it has to be purchased if you have a HW3 model. You should know if you have HW4 or not. Basically if you took delivery of a MY between late May to June 2023+ you will likely have a HW4 car.I just double check the entire wire harness going to the console. There is definitely no data port. I'll check the MCU when I get a chance.
