Voice Command "USB" -> "I can't open that service" error
vcor
Tech Specialist
Nov 29, 2012
1,433
1,031
Starting with the 2022.44.30.10 release, I can no longer use the "USB" voice command to start USB music. Tried a reboot, with no success. Tried WiFi and LTE at different locations without success. Other voice commands work fine. USB works fine by selecting an option from Recients and/or Source, but then it starts over, rather than starting from where it left off. Is anyone else seeing this? Other than the voice command "USB" I'm not aware of any other way to get USB music to continue where it left off (which is a little annoying).
"USB resume" and "USB pause" stay on streaming (but do resume/pause streaming). I'll have to wait for the car to power down to see if it will work if the USB was the last selection. Also tried pulling the USB drive, checking it on a PC (no issues), and reinstalling it. Music works fine from the USB drive, but "USB" still generates the "I can't open that service" error.
Reactions: DerbyDave
Ok, the car last played USB music. The car was off (no Sentry mode) for hours. Got in and voiced "USB Resume", the command was accepted, but spinning loading circle and no music. Recients show USB, so it has access to USB but will not start with a voice command. Tapping a USB recients choice will start USB music.
Looks like the USB startup is broken again with no known fix. Thanks for the suggestions though.
