H holmgang Active Member Sep 9, 2019 1,625 1,766 eu Feb 16, 2020 #1 Feb 16, 2020 #1 Notice the rubber seals around the door edge is lifting off What adhesive is best used to set it back?
T TLLMRRJ Active Member Dec 19, 2019 3,472 3,928 Houston Feb 16, 2020 #2 Feb 16, 2020 #2 They sell this trim adhesive in the parts store. 3M Black Super Weatherstrip and Gasket Adhesive, 08008, 5 fl oz https://www.amazon.com/dp/B00063X38M/ref=cm_sw_r_cp_api_i_VltsEb8A3T67G
Dolemite is my name Sep 19, 2019 1,404 1,845 Seattle, WA Feb 16, 2020 #3 Feb 16, 2020 #3 holmgang said: Notice the rubber seals around the door edge is lifting off What adhesive is best used to set it back? Click to expand... What specifically are you referring to?
H holmgang Active Member Sep 9, 2019 1,625 1,766 eu Feb 16, 2020 #4 Feb 16, 2020 #4 Dolemite said: What specifically are you referring to? Click to expand... couple of places similar to this with detachment Attachments door.jpg 195.3 KB · Views: 186
Dolemite is my name Sep 19, 2019 1,404 1,845 Seattle, WA Feb 16, 2020 #5 Feb 16, 2020 #5 Looks to me like it's just molding tape - you can pick it up at Walmart. Stuff is insanely strong: https://www.walmart.com/ip/3M-Super-Strength-Molding-Tape-03609-1-2-in-x-5-ft-1-Roll/16913678 Although if the car's still under warranty, SC should address it.
