BMS_u031 - Battery fuse requires replacement soon - Some questions...?
Hello All,
Seems like several threads on this warning, but wanted to confirm some specifics and latest information:
1. My S is P100D, 2016.5, I scheduled service, but the nearest appointment available to me is over a month away! With this error, is the car actually safe to drive? Or should I be sidelined for until Tesla makes time for me? Should I drive with some precautions?
2. Can anyone confirm if Tesla will cover part or all of this repair under the 8 year battery warranty? I've read both ways. What's the latest?
3. If not covered by the Tesla battery warranty, do any of the 3rd parties cover this like CarShield or XCare?
4. Anything else I need to know?
Thank you all!
Hello All,
Thank you all!
1) your car still drives fine. It's a high voltage safety issue for first responders in a crash.
2) in the beginning, Tesla didn't cover this but after complaints they now do.
3) I didn't see why not covering it.
4) Don't freak out as long as your car doesn't crash. If it does, it's a safety issue for first responders, not yours.
Reactions: Fragger
The original pyro fuse design uses a non rechargable battery to detonate the charge which isolates the battery from the car in the event of a crash. The non rechargable battery in the original fuse is not monitored, the car doesn't know if it is dead or good, so it puts an expiration date on it so hopefully it is replaced before the fuse battery dies.
The new fuse design which will be installed uses a capacitor that is charged from the HV battery. There is no concern about the fuse expiring like the original design so this should be the last and only time you have to replace the fuse.
Thank you so much for the helpful responses, my friends!
To summarize, it seems it's:
1. Safe to drive while the service appointment comes.
2. Should be covered under Tesla battery warranty?
3. Should be covered by 3rd parties as well?
Is that right?
Thank you all!
I got this message the other day, made an appointment less than a week out. We had this done on our other MS and it was a simple, 8yr drive/battery warranty free repair.
The reason for the fuse replacement. The original fuse has an onboard battery to monitor the HV battery and trigger the fuse to blow when needed. That battery has reached end-of-life (this is by the calendar and not by measuring the onboard battery power). The replacement fuse gets it power from the main pack and will not need replacement in the future.
Appointment is scheduled for 2 weeks out, cost $0.
Glad to see the additional notes on what this is about, doesn't seem like it would lead to the vehicle not being drivable. Still makes me nervous seeing that in the car all the time :)
Thanks for sharing... mine isn't scheduled for about 3 weeks out. I guess, until then, no updates for me :)...
Got the message Friday morning, a week ago.
"If I owned a Tesla with the pyro fuse mounted on top of the HV battery (Gen. 1 and Gen 1.5 batteries) then I would preemptively pay a company (such as Cedar Electric or Tesla Specialist Birmingham) to drop the HV battery, replace the fuse cover, clear the ski rail drains plus replace the umbrella valves and Rapid Mate seals. This could be a very cost effective piece of preventative maintenance because if you wait for the HV battery to fail, the cost of repairs might be ten times as high."
Any idea how to know if we have a Gen. 1 or a Gen 1.5 battery?
