Calculating Your Battery's Estimated Capacity Using the Car's Energy Screen
Status
Not open for further replies.
jjrandorin
Moderator, Model 3 / Y, Tesla Energy Forums
Moderator
Nov 28, 2018
21,911
31,422
Riverside Co. CA
Re posting here and making this a sticky post so it doesnt get lost. @AlanSubie4Life originally posted:
(originally posted by @AlanSubie4Life. Original thread this appeared in can be found here: ( 2021 model Y scan my Tesla battery size)
There is. Assuming the car is delivered at a decent SoC (above 80%):
Switch to Car -> Display -> Energy Display Mode => Energy
Then go to ^ -> Energy->Consumption screen, select "5 mile, average" and calculate:
Battery Capacity @ 100% (in Wh) = Avg Wh/mi * Projected Range / SoC%
If the data is not complete due to not enough miles, not sure what will happen, so car has to have 5 miles, maybe.
That will always give you your true battery capacity at 100%, within about 1kWh. ........
Caveat 1: Can't emphasize enough that you have to do this assessment at a decent charge level (otherwise massive rounding error will cause errors in the estimate), so emphasize you want your car charged above 70% (preferably 80-90%) at delivery.
Caveat 2: Do not perform the calculation with a very cold battery (near or below freezing); the results may not be correct.
Caveat 3: This method provides a result which INCLUDES the energy buffer below 0% SoC. On Model 3 & Model Y at least, this buffer size is 4.5% of the full pack capacity calculated; e.g., if you calculate 71kWh, your buffer is 3.2kWh (4.5%), and your usable above 0% displayed is 67.8kWh (95.5%).
Caveat 4: Important for new vehicles: This method will not produce a capacity result in excess of a certain threshold; it will be capped at that value. The value depends on the specific model. For example, for 2023 Model 3 Performance, it will not provide a value above ~80.6kWh, even if the new vehicle capacity currently exceeds that. Capacity will drop below that threshold after some time.
This method, at the current time, should work on any Model 3 or Model Y vehicle. Probably any Tesla vehicle, but no idea.
As an example, on my 2018 Model 3, my capacity is 71kWh (down from initial value of ~77kWh). This is perfectly normal and expected.
118mi*477Wh/mi / 0.79 = 71250Wh = 71kWh (only 2 significant digits, so saying 71.3kWh is meaningless)
Thanks to @AlanSubie4Life and @scottf200 for the additional clarity, and for taking the time to put together the following information to assist members (and lurkers) in easily determining this information.
Thanks again, you two!
From @AlanSubie4Life
To add clarity on how to do these calculations, please see the following link, where you can plug in your own numbers and calculate your capacity:
Here is a sample picture of the screen showing how to gather the data; selecting "Average Range" is critical:
Using an Excel spreadsheet, you can redo the calculation at any time, if you wish (this is from a Model X; this method works for all known Tesla vehicles, at this time). The kWh values are only accurate to the nearest kWh (92kWh in this case):
Thanks to @scottf200 for his suggestions.
Status
