My 2017 P100DL had the complete opposite results after the 12.5 update
I was excited to try it out today after getting the update late Friday night. I charged up the car to 100% and engaged Ludicrous + mode with max battery power. Waited for the readouts to appear on the car and took it out. I just did the same tests on March 29th with a new rear drive unit that Tesla just replaced under warranty at around 66k miles. The results were good on March 29th, but definitely losing peak power over the years down to 535kW from 565kW or so from a few years ago. I got a couple of 2.5s times w/roll out to 60mph and then consistently stayed in the 2.7-2.9s range. Today I was hoping for better times, better launches and more peak power.
Unfortunately that’s didn’t happen the initial run at 100% with Launch Control used got me a 2.56s w/roll out. I continued do 10 more runs with launch control and the times over the next several rounds were quite bad as you will see in the images. All runs were in the 3s with a massive drop off in power around 40-45mph, it was very strange feeling the power come off so early and significantly around 40mph. As well all my power stats fell off from March 29th. I also did a 1/4 mile run and that number is the highest I’ve ever gotten 11.9 at 102mph! Afterwards I went back into just Ludicrous mode and I did a few more runs. They were in the 2.9s and low 3s and a 1/4 mile at 11.4 at 109mph. I’m quite confused what happened there. I’m thinking they just didn’t get the power curve right when Ludicrous + is turned on, because it was very limited compared to normal Ludicrous mode that pulled much harder.
Hoping this gets fixed soon!!!
