Apparently there is a way to charge a dead battery without using the BMB's!
View media item 118042
View media item 118041
View media item 118040
The Tesla ESS Recovery Charger?Apparently there is a way to charge a dead battery without using the BMB's!
Is it possible to get information on the level One Battery Recovery ? I want payed this information . I am in France ...The Tesla ESS Recovery Charger?
Am I correct the small VDS screen remains dark even with a charged 12v battery? If so sorry but you are beyond my knowledge. If the VDS works I can likely help a little.Is it possible to get information on the level One Battery Recovery ? I want payed this information . I am in France ...
Hello, what is the voltage we are supposed to measure on the service disconnect terminal when the plug is removed ? 0V, a part of the total voltage or the total battery voltage ? My question is : this voltage measurement can give a first reliable information about ESS health or not ?
Thanks
I'm confused, or maybe it's the car... Looking at the ahr.log file, it appears that my brick #9 is the odd one in my pack:The best way to get an idea of the pack health is to get voltage measurements of each brick over some delta time. Every time you pull a log file, the tarball that the Roadster zips up for you contains a file with all the brick voltages—third column in ahr.log. Copy the values into your preferred spreadsheet editor and divide each value of the column by the factor 8192 to get each brick's measured voltage. The brick numbers are in the first column in zero based format and the bricks ordering scheme is outlined here.
