3280 here getting 122kw in Gilroy (I know it's probably rounding error).
I got 122kW myself. Doing the calculations it was 121900 watts... so the rounding appeared correct.
Wonder what their gain/offset errors are in the voltage & current sensors...
Sig 520, max 250Amps and 90kW at fastest charge on brand new Supercharger.
I did use the voltage & current readings from another person in the thread who posted a screenshot of their 122kW session, and they also calculated to exactly 121,900 watts also...
I meant if there is 1-2% error in their (Tesla's) power sensors' accuracy, that could easily account for 122kW being reported (above the theoretical charger max of 120kW...)
Sure... I was just throwing out the other data point I had... it would be rather coincidental for the error to end up the exact same value on 2 different cars.
That having it been said, I've seen it reported here that the Tesla chargers (used in both the cars and the supercharger stacks) are actually capable of accepting 277VAC (a common commercial voltage) at up to 40A. That actually works out to be 11.08kW each.
Given the stack of 12 understood to be in each supercharger, that could actually deliver 132.96KW. So simply some supply-side line voltage fluctuation might allow them to put out slightly more than 120... provided the car was willing to accept it.
As a matter of fact, that figure rounds to 133kW... awfully close to the 135kW Elon mentioned in Europe...
I don't think you can compare the AC input to the DC output. There is loss and the US spec chargers cannot deliver 11 kW DC to the battery. More like 9.6 kW or so.
Which supercharger?
Could we get confirmation from someone else with a higher VIN that it does indeed charge above 90kW?
Now that we have all but confirmed that this is a hardware limitation (Tesla has confirmed this twice to one of our members) there isn't much of a point in doing any more detective work to figure out what the maximum SC output is. I was holding out hope that this could have been causing the issue, but not any longer.
Now it's a question of how we proceed and determine why TM never communicated anything about a hardware issue to Sig owners.
Actually, up to their limit for current and voltage, the AC input does affect output. That's why, for instance, HPWC's running on commercial 208V circuits only put out about 8.3kW per charger.
If your figure were correct, that world mean the stack of 12 chargers in a supercharger cabinet could only supply ~115kW...
My figure comes from 240V x 40 A = 9.6 kW which is most AC input I can get on a single charger. I see less than that as DC input to the pack. I guess each charger must be able to go higher in a supercharger configuration though or as you say, the numbers don't add up. The North American chargers are quoted at 10 kW each and the Euro chargers are shown as 11 kW each so a stack of 12 of the Euro version chargers should be able to get ~10% more energy. I think thats how Elon gets from a high end of 120 kW in the US to the 132ish in the Euro superchargers.
well I've been told by Tesla that the very early cars, basically all the sigs, are running with many 'prototype' parts that later production cars have better/newer versions. For example, things like older/different embedded ROM chips that run different firmware etc etc. Some (many?) of these cannot be "upgraded" (aka chips soldering into boards, not plug-and-play). so if sigs are limited to 90kWh charging , this isn't really surprising to me.
Exactly! As an early Sig buyer (#37), I was very aware that this would happen. If this were a huge difference in charging time, then it would be important to me. However, as I stated before, its only about a 5 minute difference if you start at 0 miles. The taper goes below 90 kW at about 100 rated miles. 0 to 100 rated miles at 120 kW (400 mph) takes 15 minutes; at 90 kW (300 mph), it takes 20 minutes. After that, you are in the taper anyway.
I'm not getting too excited over a 5 minute loss in charge time for my early Sig. :wink:
I was never told that my car is a prototype.
