Hankook iON EVO All season tires with controlled efficiency testing
I installed the 235/45/18 Hankook iON EVO All Season tires on my 2022 Tesla Model 3 Performance with T Sportline TS5 18x8.5 wheels last week.
I have done a very controlled efficiency test with the tires below. The test is a 25 mile loop around our beltway that starts and stops at the same place. I record GPS time, distance, and average speed so that the test is consistent no matter what wheels and tires I have on the car.
Wheels and tires tested:
1. 20x9.0 Uberturbine wheels with factory 235/35/20 Pirelli PZ4 Tesla specific tires.
2. 18x8.5 T Sportline TS5 wheels with non Tesla specific 235/45/18 Michelin PS4S tires.
3. 18x8.5 T Sportline TS5 wheels with non Tesla specific 245/40/18(undersized diameter) Pirelli PZ4 tires.
4. 18x8.5 T Sportline TS5 wheels with brand new(<100 mile) 235/45/18 Hankook iON EVO All Season tires.
The 245/40/18 Pirelli PZ4 tires were about 1/3” undersized on the tire outer diameter so the wh/mi reading is optimistic for that tire. The car thinks it went about 3-4% further than it actually did. 220 wh/mi is a more realistic number for that tire instead of the 212 wh/mi that the trip computer said.
As you can see the Hankook tires are about 18% more efficient than the original Uberturbine wheels and PZ4 tires.
The Hankook tires were about 8%-10% more efficient than either of the 18” summer tires even though they were all on the same wheels.
I am thoroughly convinced that the efficiency claims of these new Hankook iON EVO tires are accurate. They are incredibly efficient.
These Hankook tires have a 50k mile guarantee and they have a 600 Treadwear rating on the tires.
I pumped the tires up to 42 psi as recommended and I noticed that the tire pressure didn’t change that much from that value even after extensive driving. In fact it even went down slightly in the rear tires after a drive. That is really good that it maintains a consistent pressure throughout the drive. All of the other tires would get up to as much as 46 psi after a similar drive.
I did a 220+ mile drive each way this weekend with the new Hankook tires. Going out there was a torrential rain storm for about 165 miles. This wasn’t normal rain. It was more like flooding on the interstate. I could feel the standing water causing drag on the car.
I averaged 280 wh/mi going out until I stopped to charge. However, it stopped raining and cleared up while I was charging. I averaged 226 wh/mi for the next 55 miles but that was at a slower speed going up the mountain.
Standing water on the road absolutely destroys your efficiency no matter what wheels and tires you have on the car.
Coming back home I averaged 207 wh/mi in my 2022 Model 3 Performance for 220+ miles. I had the A/C on 66 degrees F the whole time and I averaged 61.2 mph according to the GPS app.
I also was able to do 142 wh/mi for my 12 mile highway commute into work. That is at a much slower speed(~51 mph average) because of construction.
I haven’t been able to measure a difference in noise with my SPL meter. The Hankooks and the 245/40/18 Pirelli tires were measuring the same DB value. They definitely aren’t any louder but I really couldn’t tell the difference in sound. They both sound quiet to me.
I paid $1077 for the tires installed at discount tire. They price matched some random online retailer for $224 per tire.
If I get the 18 inch wheels can the tire monitoring system be moved from the 20 inch to the 18 inch or will I have to buy new TPM’s?
TPMS sensors are independent of the wheels.
You can move them to a new set of wheels if you don't plan to use the old set. Or buy another set, if you plan to utilize two sets of wheels (winter vs. summer, track vs. summer, etc.).
HTH,
a
As a new owner, I read this and other tire threads with great interest. I didn't realize how significant a range factor the tires could be. The 2016 S I just bought came with Goodyear Eagle Touring 245/45R19, I'll look into a set of these Hankook's when they need replacement.
Reactions: Tezla041 and Pommie
A friend needed new tires and I pointed him to these Ion Evos. He got them installed a few days ago. He said he wasn't a "car guy" so I am not sure if I am going to get any feedback. We both truck our kids to sports all over the place so hopefully he will be able to tell if his range is better or worse. This Sunday is a 144 mile round trip... we shall see!
He did get over 30k miles on his original MXM4s (2019 M3) so I hope these work out for him.
Reactions: Tezla041
30k is pretty good then again the 2019 Michelin may not have been the Turd my 2023 MXM4s where i got 15k and had issues with foam liners coming loose (one tire that had issues was plugged the other was as far as I know never had a nail or screw) also had high/low spots i went to Discount tire to get my foam liners removed that where loose but they found the high and low spots on my tires so ended up getting talked into the Defender 2s…disappointed road noise, bad efficiency mainly but also the echooooooooo is annoying. Talked to them today have the ion evo as enroute should be on the ions wed afternoon. If not sooner.
Reactions: Discount Tire
I still have the OEM MXM4 tires. Probably my last season with them. 32,000 miles and I've plugged them myself 3 times. No issues with foam.
I was hoping to get 5-6 more k by getting the bad liners removed one that i got to look at in person seemed to be very little glue/adhesive compared to what one would expect…but never got to compare to the ones that didn’t detach.. all the plugs except for 1(was at a Mechanics shop working on his computer with pouring rain and noticed one tire was VERY low when leaving so he plugged it for me and he recommended this Amazon.com) and my father helped me after i got a screw at his place…and had 2 more small screws also probably from my fathers place but could not prove it. (Both bad tires with foam issues where 4022 the tires that didn’t have issues where 4122 so that could be a coincidence too…)
I will Confirm the Hankook Ion EVO AS are Excellent so far there is still SOME road noise to be expected but comparted to the Defender 2 tires, the defects in the road are quieted down(Cracks, small potholes, rough asphalt), the Echo is gone which was the most annoying part of the Defender 2s to me. the Mileage is back to where I expected, will see how it does this weekend have a 140-mile round trip, next weekend have a 200+ mile round trip to take next Saturday.
if I recall correctly the MXM4s may have been quieter at the beginning BUT it could also be that I wasn't used to the quiet at the beginning. but will never go back to the MXM4s and will take the best reviews ever to ever get me to go back to Michelin again.
Reactions: mpgxsvcd
Just got the Hankook Ion EVO AS tires installed today. MY OH MY! These are AMAZING! Yes I had worn my Michelin Pilot Sport S Tires down to where my friends were suggesting it was time for new tires. But the thumping noise for the last few thousand miles coming from them was insane!
Got the Hankooks for my summer trip all over Colorado and can’t wait to report back later that I still love them. My #1 concern was noise. I simply wanted quieter tires.
