Hit a curb, how screwed am I?
Hi all,
I hit a curb while turning out of a parking lot today. Damage is attached. What do you think it will cost to fix it?
It really doesn't look that bad. the black rocker panel cover will set you back about $499 with install, if you go that route. I know this because I had to replace mine last summer. As for the rocker panel itself, it should be an easy fix without screaming blue murder on the costs. Bear in mind though, that Tesla paint work tends to be slightly more expensive. best of luck with that.
