I'm new to the ev world but ice mechanic for 32+ years. Trying to learn. Working on a 2013 model s with fatal battery codes. Battery appears to be ok based off of scanmytesla but has hv internal isolation failure codes. Battery is out and opened up, but before going any further i did a quick voltage test from the (forward) terminal at the pyro fuse (fuse removed) to the battery shell and get 170 volts. I'm assuming the case should not be electrically tied to the hv battery. I have a fluke 1508 on order, but seems to be more obvious than that. Thoughts? Am i wrong about my case voltage?
Thanks
Thanks
