The hardware is not the same if they are binned. The design is the same but because the manufacturing process has variations the post build outcome is different. Binning puts the better build outcome into the P bin and the worse build outcome into the AWD bin. So they are not the same by definition otherwise there wouldn't be in separate bins.The act of binning is in itself a confirmation that the hardware is the same - you can't bin parts that are of different specifications.
"Binning" and "double burn-in" is probably all marketing hype and likely makes little to no discernible difference in performance or longevity, folks getting their AWD cars flashed to P is confirmation of that.
Correction, 9K more for- one second faster and 14K more for 10mph more top speed. You don't get the 10mph more with just the base performance.I hear you but that is not what it says. I guess the best way to know is to measure the rotor diameter and see what size it is on the Performance model without the upgrade. Look at page 140. It talks about non-performance and performance and not about any upgrade. if what you say is correct, what are you paying 9K more for- one second faster and 10 mph more? Are there any other improvements to warrant the price increase?
Have you seen those separate bins in the factory? I think based on all available evidence ( Elons tweet not withstanding) that AWD cars are just software limited Performance cars. The rear motor output is the same for RWD and P cars. Do you think they have been giving binned motors to RWD cars from the beginning, with the plan to give the lower output motors to the AWD cars?
Still does not explain that RWD rear motors have same output as P motors.Adjusting the SW on cars that were ordered as P is not very convincing to me that all AWD are also P.
If my thermal hypothesis is correct, short term peak power could be the same for all parts. However, the motor binning would directly impact the number of laps you can get out of your P on your favorite track before thermal limiting kicks in. Or km at high speed on the Autobahn.
Without binning, one person might get (for pure example) a P that goes 5 laps, while another gets only 3. Given there are only 2 bins (unless P+ is a third bin), some Ps may (for example, not real numbers) do 5 laps while another does 6, all do at least 5.
The other (potential) factor is high speed balancing. All rotors are high speed balanced after assembly (>10k RPM). The P and P+ may have better balanced rotors (due to process variation) and so can handle the higher RPM of their top speeds. In which case, the drive unit test stand also has vibration sensors/ accelerometers to validate. Force (acceleration) due to vibration increases as the square of RPM, so this could explain the 10 MPH top speed increments...
An interesting thought (to me at least) is that this could open up a new era of modding where people tear down their drive units to hand select the best SiC power FETs and hone the thermal interface to get the maximum power for the longest time. Only useful for race conditions....
Again, do you really think Tesla has been using the higher spec binned motors since the beginning of production? All the while saving up the lower spec for the 6K AWD upgraded cars that would start production 1 year later.
I think what you are trying to say is that the design and manufacturing process is the same and yes that is true.
Elon is the one that stated the motors are binned and have double burn-in to verify performance. He is not one for marketing speak. He has always been straight forward and scientific in the comments he makes so I believe him.
First off, that is the rated power spec for the motors (software limited), who knows what the real power limit is/ headroom.
If the issue is thermal and balance, all drive units can put out the same peak power. Where they would differ is in how long they can put out high power (integral of power dissipation) and the maximum safe RPM they can sustain (maximum speed limit).
The S has more power than the 3, but will overheat on the track, that's the kind of thing I'm talking about.
RWD top speed is 150, P+ is 155, that is a factor of ~11% which means that off balance loads increase 23%. For the same bearing loads, the balance needs to be that much better.
Induction motors have heat issues that PM motors do not. That is why Tesla uses PM (SR) for rear motors in the 3.Yes, we are saying the same thing. From an engineering perspective the parts are the same if they are the same part number. They are designed and built to a certain spec and as long as the parts meet that spec they are the "same". Unless Tesla has assigned a different part number to P builds then I would take that as a pretty significant clue that there is no appreciable difference between the binned and non-binned parts.
I would attribute the overheating on the S to the design of the thermal management system, not so much the drive unit(s).
I'd contend that manufacturing variances from one motor to the next is small enough to not make a difference in performance or longevity when dropped in a P or an AWD.
I ordered AWD but they gave me performance version. I can see the redline in the app and car. My cousin ordered AWD he did not get the red line. The car does 0 to 60 in 3.5 seconds.
I wouldn’t be posting that on a public forum. Haha.I ordered AWD but they gave me performance version. I can see the redline in the app and car. My cousin ordered AWD he did not get the red line. The car does 0 to 60 in 3.5 seconds.
Does that printout then resolve the whole “is it 75 kWh or 80.5 kWh” debate? Seems like 75 kwh is the usable portion and is consistent with my driving experience/rated vs actual range data.Ok I am now happy again. Whether or not the hardware is different I’m not sure. But if there a difference I have the performance setup. Thanks to an amazing and relentless service tech here in Vegas all has been resolved. They flipped a switch and I received the performance identifiers red lines , menu option and definite speed upgrade. Not a download of any kind but just opening up the options. To prove it I was given the attached paper. Notice the P75D and performance package noted. Also birthday is Sept 26View attachment 340225View attachment 340226
