yep. and I also had all those HVAC issues with numerous service center visits, until they've disconnected the CANBUS. But it looks like the car started to behave overnight, maybe it fell asleep and woke up in a good mood lmao.Do you have the Tesla Powered Trunk retrofit?
Jokes aside, it looks like the car needs to be almost completely shut down for the trunk to start working, so 12V and HV needs to be disconnected. I tried to completely disconnect the liftgate ECU, it didn't do the trick, so some other ECU needs to be restarted. Another question is whether the car will go asleep if the liftgate ECU canbus is still connected. I had to connect it back to update the ECU SW, but disconnected it afterwards. Will reconnect it later to check if the original issue with the car unable to go asleep is resolved.
