It is my understanding the older V3 Wall Connector works with Powershare if you have any version of Powerwall? If you do NOT have a Powerwall, you will need the newer Universal Wall Connector and the new V3 Gateway? Does anyone know exactly what the internal electrical differences are between the two Wall Connector versions as it relates to delivering power from the Cybertruck to the home?
Regards, Ron
1. It is my understanding the older V3 Wall Connector works with Powershare if you have any version of Powerwall?
Yes.
For Customers with Powerwall
If your home is equipped with Powerwall and home charging, you do not require any additional equipment. Powershare Home Backup functionality with Powerwall is expected to be available later this year through an over-the-air update. All AC Powerwall variants will be compatible with Powershare Home Backup in the future.
The home charging unit can be any product,
but we strongly recommend it’s
connected to a 240V circuit. Our preferred solution is the
Wall Connectoror
Universal Wall Connector. Any generation of Wall Connector is compatible with Home Backup if using Powerwall. The home charging system must be
backed up by the Powerwall system to enable Home Backup.
2. If you do NOT have a Powerwall, you will need the newer Universal Wall Connector and the new V3 Gateway?
Yes.
For Customers without Powerwall
For homes not equipped with Powerwall, a Universal Wall Connector and Powershare Gateway will be required to use Powershare Home Backup.
3. Does anyone know exactly what the internal electrical differences are between the two Wall Connector versions as it relates to delivering power from the Cybertruck to the home?
I don’t know exactly but the universal Wall Connector can enable bi-directional charging.
Universal Wall Connector enables bi-directional charging, allowing Cybertruck to either charge or power the home when plugged in.
Source:
https://www.tesla.com/support/powershare
